Re: DATE after DAYS algorithm ??? Message #2 Posted by John H Meyers on 27 June 2000, 3:10 a.m., in response to message #1 by Tal
I dimly recall seeing the formula for assigning a "day number" to any date, either in an HP12C or HP18C manual, although there was a term missing in it!
The problem is then to work it backwards, to get the date from the day number. This is easy enough that I programmed it once for my HP15C, but it's not at hand for me to copy, just now.
Simple formulas for doing this are widely published, and HP has no secrets here! IIRC, Jim Donnelly's "HP48 Handbook (2nd Ed.)" had such a pair of formulas, taken from an astronomy handbook.
A little search on Internet or at a library should turn up what you want.
