Re: AC POLARITY HP95-LX Message #3 Posted by Bill Duncan on 13 June 2000, 2:39 p.m., in response to message #1 by Erwin
AC doesn't have polarity, although in some cases (like the mains) one side is "Hot" with reference to ground.
According to my hp wall-wart for my hp-95lx, your solution might be a bit underpowered, and it seems to be DC.
The specs on mine are 9VAC, 13.5 VA.
Now your DC adapter "might" work, if the 95 does full-wave rectification. I wouldn't suggest it however.
And regardless, unplug it when not in use. For some reason it seems to drain the batteries faster, perhaps with some leakage current. But I haven't been able to verify. Your mileage may vary.
