Re: HP IL problem Message #2 Posted by Reinhard Hawel on 6 June 2000, 10:00 a.m., in response to message #1 by thib
Forget "ASSIGN IO". This is mostly for compatibility to the HP 80 series and the 75. I don't know anybody, who works with it on the 71.
Additionally, I believe, you also must assign the printer
ASSIGN IO ":DD,:PR"
Use the device ID instead of ASSIOGN IO.
Example: PRINTER IS "HP82161"
Example: COPY xxx TO "HP9114"
This should get both working.
I remember, that I wrote a short article in this forum abt IL addressing methods and working with devices. I'll try to find it again and I will publish the link here.
