Re: HP67 Card Reader Problem Message #2 Posted by Matthew Riehl on 22 Apr 2000, 10:42 p.m., in response to message #1 by Alex Lee
The original parts are no longer available. You can make replacements out of either tubing (R.C. aircraft fuel line or refrigerator water line) or with rubber O-Rings.
I have rebuilt a couple of these now and have used rubber O-Rings on both of them, with very good results. You can get the O-Rings at the local ACE hardware store for about 15 cents a piece, you will need two of them. The size that you want has an I.D. of 1/8" and an O.D. of 1/4". This is the perfect fit for these machines.
Just clean out all of the old gooey stuff and fit these onto the drive wheel. Be sure to read the article on HP-67 repair by Steve Loboyko on the repairs section of this site as it is full of good information. Good luck.
Matt
