Re: HP 41 Wand 82153A malfunction Message #2 Posted by Wayne Brown on 10 Apr 2000, 8:36 p.m., in response to message #1 by Bill Smith
I've had occasional problems with my wand on one of my HP-41s. It has the same problems you describe--working intermittently and sometimes improving when the connector is wiggled. In my case, it works better in some of the 41's ports than in others. The worst problems are with port 4; since that's the card reader port, it's gotten much more use (and wear) than the others. Apparently the wand is more sensitive to a loose-fitting port connection, because it shows the problem much more often than any of my other plug-in devices. Try moving the wand to another port.
Also, I've found that when the wand behaves this way, it can get the 41 into a state in which it seems to function normally but can't recognize the wand properly in any port. So now, anytime the wand gives me trouble, I unplug it and plug it in again, then do a master reset (the ON-BACKSPACE and MEMORY LOST variety) before trying again. That often helps.
