Re: Help to install libraries in HP49 Message #6 Posted by paul w on 22 Apr 2000, 3:07 a.m., in response to message #5 by macutan
hey macutan
i dont have much experience on the hp49g but on the hp48g to load a library i recall the library to the stack
eg for a game called tetris this is how my stack looks
4 : 3 : 2 : 1 :Library 1117:tetris
then i type 0 then STO
this stores the library tetris to port 0 (zero) or if i have a card in port 1 i could store the library in port 1 (i would type 1 STO )
the next thing i usually do is turn the calculator off and then on again . this usually loads the library file to my hp48s inbuilt library (-> 2 ) it automatically loads because the library (in most cases) has a routine created by the person who made the library but if it doesnt automatically load then i have to attach the library (hp49 has the ATTACH function too ) to the home directory using the libraries distinct number (eg for tetris use 1117)
4: 3: 2: 0:1117 1: ATTACH
notes ----- * tetris is not contained in a library numbered 1117 this is only an example * this method works (i think ) on the hp48g and probably also on the hp49g (can someone test this for me )
hope this helps
paul
