Re: Where is it???? Message #3 Posted by Matt on 31 Mar 2000, 12:06 p.m., in response to message #1 by Laurie Muglia
Where's the museum? You're soaking in it.
I think if primary school students spent a year or two working with slide rules at the same time they're learning about ratios, scientific notation, and logarithms (etc), they'd be a LOT better off down the road. You get an intuitive feel for the principals behind basic math from using a slide rule that you aren't likely to pick up any other way.
Anyway you've probably found it by now (but just in case) the definitive slide rule resource is at http://www.sphere.bc.ca/test/sruniverse.html
