HP49G INPUT HELP! Message #1 Posted by Mike on 25 Feb 2000, 12:06 p.m.
Does anyone know how to do the following on the HP49G?
The format of the INPUT command is...
"PROMT STRING" { "Command Line" { r c } option }
My input requests either Yes or No by using the following INPUT syntax...
"Choose Y or N" { "Y or N" { 1 7 } V a }
I'd like to use the following...
"Choose Y or N" { "(Y/N)" { 1 7 } V a }
The problem is that placing a ( and / into the command line produces an illegal syntax in the INPUT command. I've tried "\(Y\/N\)" but with no improvment.
Help!
Thanks
-Mike
