Re: HP55 display problem Message #2 Posted by Viktor Toth on 12 Feb 2000, 11:26 p.m., in response to message #1 by Erik Wahlin
Erik,
I have had an HP-55 with a display problem that I eventually traced back to a faulty diode and a dead transistor on the main board.
Two questions; first, does this dead segment light up with normal, full intensity, or is it lit just faintly? Second, does the calculator show any signs of life? When you press buttons, for instance, does the display flicker or change in intensity?
Viktor
