Re: hmm gettin closer...? Message #4 Posted by Erik Wahlin on 12 Feb 2000, 7:36 p.m., in response to message #3 by mark french
Mark, When you copy a program, you have to set the switch to program and then run the card through. If it gives you crd (because your program is more than 112 steps), you have to run the other end too. To write data from the storage registers, the switch must be in run position, then hit w/data key. It will give you crd to prompt you for inserting the magnetic card.
Write data is only for saving data from the registers to the card. I think this was your confusion.
By the way, if you are loading a program into the HP97, make sure the switch is set to run, or you will over write the program unless the write protection tab is clipped.
