Re: HP45 Power Supply Defect Message #2 Posted by Joe on 19 Jan 2000, 7:48 a.m., in response to message #1 by Thomas Winterling
Thomas,
Open up the charger and check the output voltages there. I should be ~5.1VDC and ~17VDC. The wire to the charger plug is usually what breaks. It usually breaks right were it goes into the plug. No, there are no replacement cords. Your only option is to carefully cut the plug apart and try to reconnect the wires.
Joe
