Re: openning HP-33E Message #2 Posted by Viktor Toth on 13 Dec 1999, 10:52 p.m., in response to message #1 by Jerry Doctor
Pry it a little beyond 45 degrees. You'll hear a loud SNAP and your heart will stop because not only is the noise really LOUD, you'll be convinced that you have just ruined your machine.
In fact, you'll just have managed to separate the top and the bottom halves.
Before you do this, make sure that the battery connector remains attached to the top half (i.e., when the halves separate, you don't rip out the flexible connector by mistake.)
Usual disclaimer... do this at your own risk. Worked for me, but that doesn't mean that it'll work for you.
Viktor
