Re: HP 41 screw posts - broken Message #4 Posted by John on 24 Nov 1999, 7:26 p.m., in response to message #3 by Chris Morris
Not quite the same problem Chris, I have a good case back, it's my case front that has cracked an broken posts where the screws screw into. All we need to do is find a dead calc with a good case, you can have the back, and I can have the front, and both our problems will be solved !!. - Thanks, John.
Thanks to the other Chris too for his suggestion, but I think I'm going to follow Stefan Vorkoetter approach from his article, and do some soldering, that way I won't have to really care about the screw posts.
