Re: HP-25 Battery Pack Message #2 Posted by Viktor Toth on 2 Nov 1999, 2:05 a.m., in response to message #1 by Alan
Alan,
2 NiCd cells is precisely what the HP-25 is designed to operate upon.
The metal bar is not really necessary, the springs connect the two cells just fine. If you want to do a real nice job, however, buy NiCd cells with solder tabs; you can then solder the two cells together to ensure a good connection, and rip the solder tabs off the other ends.
Viktor
