Re: Blank the menu levels in HP48. Message #3 Posted by Joe Panico on 31 Oct 1999, 9:35 a.m., in response to message #1 by Tal
Tal, You can blank the menu by the command TMENU using a empty list - opening and closing curly braces with nothing inside {} - on stack level 1 (I'm not sure if the braces {} will copy on this post, so I just described them) This will produce a set of menu keys without titles.
If you want to completely eliminate the menu and pick-up the last 8 lines of the display:
build the display you want as a graphics object (GROB)
in a running program, display the GROB
at the end of the program, TEXT to return to the stack
Without checking, I think the [ON][SPC] mode suspends the running clock. As far as other changes I don't recall.
Joe
