Re: IR printer compatibility Message #3 Posted by Andrés C. Rodríguez on 1 Nov 1999, 7:23 a.m., in response to message #1 by Kevin
There was a description of the IR printer protocol in an issue of the HP Journal, in the October 1987 issue.--- The article title and authors are: An Infrared Link for Low-Cost Calculators and Printers-- by Robert S. Worsley, Bruce A. Stephens, Steven L. Harper--- If memory helps, the protocol is similar to an asynchronous serial link, the bits are coded based on the timing of pulses that modulate a 32 khz carrier. It seems to be similar to the system used in infrared remote controls. It appends a 4-bit checksum to each byte, the strange detail is that the checksum is calculated by means of an AND function instead of the usual XOR.--- If you search this Forum and the archived Forum messages here at the Museum, you will find references to PC programs that intend to be compatible with this link, allowing transferring data from a calculator to a PC. I am not able to endorse any, since I have not tried them.
