HP-67 - AC Adaptor To Calculator Connection (No Power) Message #1 Posted by Tony Palsmeier, Jr. on 20 Oct 1999, 3:54 a.m.
I have recently experienced a problem, in which my HP-67 does not receive power from the AC adaptor. The adaptor plug to calculator (socket) connection is snug, but no power is received by the calculator. However, when I apply pressure to the plug in an upward direction the calculator receives power. The 3 electrodes on the calculator seem tight, and the plug does fit tight in the socket on the calculator. Has anyone experienced this problem? If so, is there a (relatively painless) fix for it? Thanks
