Re: HP67 Black Label on Back Message #3 Posted by Stefan Vorkoetter on 27 Oct 1999, 3:37 p.m., in response to message #2 by DaveC
I had given some thought to this a while back, and came up with the following idea:
1) Buy a sheet of sticky back label paper from Avery. 2) Spray paint it with a good quality lacquer-based silver paint and let it dry thoroughly. 3) Laser print over top of that.
The only possible problem I see is if the printer melts the paint, but I don't think it would as long as the paint is a lacquer.
Use at your own risk
Stefan
