Re: HP41 Fault, Any Ideas? Message #3 Posted by Steve on 23 Sept 1999, 8:30 p.m., in response to message #1 by Ian Phillips
I had a CV that exhibited some rather strange faults, including refusal to power up at times, turning off at odd times, strange display stuff...
In my case it was the links between the display pcb and the keyboard pcb. These are soldered. SOme of the connections had fractured, and others had lifted the track on the pcb.
Have a close look at these, especially if pressing harder on the keys, or flexing the case slightly makes the problem worse.
