Re: HP17BII - time calculations Message #3 Posted by DaveC on 16 Sept 1999, 3:19 a.m., in response to message #1 by Brian
Brian - the 17Bii has the solver application. This is written without a manual to hand there may well be HMS calculations on the 17. What you would do is input a calculation with the unknowns HH,MM,SS,DIST performing the manipulation described by Randy above. When the solver is run, it determines that it needs HH,MM,SS,Dist and lables the soft keys at the top of the keyboard with these mnemonics. You then input the number of hours and press the softkey labled HH and so on.
