Re: HP 67 Program Library Message #4 Posted by William L. Drylie on 19 Sept 1999, 7:56 p.m., in response to message #3 by James D. Collins
James, I'm not sure who to contact. This was quite awhile ago when the hp calculator support was still in corvalis. When I called support over a year later, they had moved to colorado. The fellow I talked to was no longer with calculator support, and the young people there knew nothing of the users library. In fact, the young man I talked to had never seen an hp 67! They seem very reluctant to answer questions about the older calculators, stating that the older machines are no longer supported. I'm also pretty confident that if you find the users library, in order to use any programs, you would probably have to become the custodian of the entire library, if that is still possible, as when I asked for hp 67 programs/application pac copies the fellow declined from selling me the copies I asked for. I would start at hp corporate headquarters?, maybe they can point you in the right direction. Good luck!
