Re: hp-41cv terminals Message #2 Posted by Dan Grelinger on 20 July 1999, 10:58 p.m., in response to message #1 by Eduardo Gangoiti
Eduardo, Your last comment is correct. The HP device to use the connections you describe was never delivered, and HP eventually stopped putting them in the 41's. They only exist in early models. The hole was eventually used to connect the charger to the Ni-Cd battery pack that was sold for the HP-41, but the electrical connection is through the battery pack, not directly to the calculator
