Re: HP-65 works only with adapter: why? Message #4 Posted by Steve on 5 June 1999, 11:33 p.m., in response to message #3 by Gianmaria Porrini
Dave was referring to problems with the connector where the charger plugs in, not where the batteries go.
A quote from the page he suggested you visit:
"Sometimes, classic batteries seem to be dead because surface corrosion has built up in the springy piece that connects two of the charging posts when the charger cable is removed. Try cleaning them with a pocketknife or fine sandpaper."
There is a diagram of the offending part on that page too.
Steve
