Re: HP-71 and HP9114B Message #2 Posted by Dan Grelinger on 19 May 1999, 10:04 a.m., in response to message #1 by jeff
I have a couple of 9114B's, but not an HP-71, so I can be of limited help. The first thing to try is to put a formatted diskette into the drive with the power off, and then turn the power on. The drive will perform a self-test using the inserted diskette. I assume that this test includes writing and reading to the drive. If that passes, then I would look for a file VERIFY command on the HP-71. One exists in the HP-IL functions of the HP-41. This verifies that the file can be read successfully.
