Re: HP-9114B Cassette Deck Message #2 Posted by Steve on 6 May 1999, 7:24 p.m., in response to message #1 by jeff
Some simple tests first
NB these are based on HP41 HPIL experience
Are your cables OK? Try looping them from one connector on the 71 to the other. The 71 shouldn't find the device, but it shouldn't report a broken loop either. (do this with each cable).
This should do a basic test of the 71 and the cables.
If this works, then start to suspect the Cassette drive HPIL interface (which you probably already do anyway :-).
There are a number of things that could have gone wrong. I have some vague details of how HPIL worked, but let someone else with experience help out here (all my stuff works, and if it aint broken...)
