Re: HP 41 alpha key Message #3 Posted by DaveC on 3 May 1999, 7:00 p.m., in response to message #1 by Doug
Well Andres I understand you not wishing to go back to the 48g - too complex by far and not enough help! Anyway, before you try reassigning the alpha key, flood the switch with isoproponal alcohol (about 4 drops) and while pressing the alpha key, move it up and down a few times...sometimes the gold gets worn and the switch contacts oxadise...this fix is worth trying with dodgy on-off switches (just before you post them to someone else...)
