Repeating Decimals / Recurring Decimals
01-21-2018, 11:00 AM (This post was last modified: 01-21-2018 04:34 PM by StephenG1CMZ.)
Given an integer reciprocal, analyzes the decimal representation to identify the transient and repeating/recurring parts of the decimal.
Eg
1/3 has no transient and 3 repeats.
1/4 has transient 0.25 and no repetition.
1/7 has no transient and 0.142857 recurring.
1/14 has transient 0 and 6 recurring digits.
See http://www.hpmuseum.org/forum/thread-9919.html
For a description of the algorithms and more examples.
Stephen Lewkowicz (G1CMZ)
01-21-2018, 11:01 AM (This post was last modified: 01-21-2018 11:34 PM by StephenG1CMZ.)
RE: Repeating Decimals
(PPL) Version 0.2 follows the sequence of steps in Joe Horn's algorithm using MultiplicateOrder, which can be found here: http://www.hpmuseum.org/forum/thread-3212.html
Output is currently a list:
1: {Length of transient, transient}
2: {Length of recurring part, both parts but omitting the 0. Or 1.}
3: Just as a check, the real value.
The formatting could be improved.
Note that if the length of the recurring part exceeds 12 the recurring part returned is unreliable and should probably be replaced by NaN (the indicated length is OK, but not the digits...and sometimes they are not digits).
 LOCAL CRID:="REPEATING DECIMAL (PPL) V 0.2";
 //Written 2018 StephenG1CMZ
 //Following Joe Horn`s algorithm using Multiplicative Order
 //This implement yields some useful results but
 //Large Repeating Lengths (>12repeatingdigits) yield weird output eg NN=301
 //The output format could be improved.
 LOCAL ImpRELEN:=12;//EMPIRICAL
 LOCAL FR2,FR5;
 EXPORT TESTED:={};
 ZEROS(NN)
  IF NN>0 THEN
   RETURN "0"+ZEROS(NN-1);
  RETURN "";
 TRUNCRR(NN,DIGITS)
 //TRUNCATE A REAL RECIPROCAL
 //NN:DENOMINATOR
 //DIGITS:NUMBER OF PLACES TO KEEP
  LOCAL TP;
  TP:=(1/NN)*10^DIGITS;
  TP:=IP(TP)/(10^DIGITS);
  RETURN TP;
 EXPORT MAXFACTOR25(NN)
  LOCAL MAXFACTR:=0;
  LOCAL LST,LSTB,LP,II;
  LST:=mat2list(ifactors(NN)); //BASES AND COUNTSETC
  //EXTRACT BASES (2,5) ETC
  LSTB:=IFTE(SIZE(LST),MAKELIST(LST(2*II-1),II,1,(SIZE(LST)/2)),{});//{} HANDLES NN=1
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
   FR2:=LST(2*LP);//EXPONENT
  LP:=POS(LSTB,5);
  IF LP THEN
   FR5:=LST(2*LP);//EXPONENT
  MAXFACTR:=MAX(FR2,FR5);
  RETURN MAXFACTR;//0=NONE
 EXPORT GETTRANSIENT(NN)
  LOCAL TRANSIENTLEN,TRANSIENTPART;
  TRANSIENTLEN:=MAXFACTOR25(NN);
  TRANSIENTPART:=TRUNCRR(NN,TRANSIENTLEN);
  RETURN {TRANSIENTLEN,TRANSIENTPART};
 EXPORT ReDIGITS (NN )
 //NN INTEGER
  LOCAL TRANSIENT; //TRANSIENTLEN,TRANSIENTPART;
  LOCAL WHATSLEFT,MO;
  LOCAL RP,NDIGITS;
  LOCAL ST;//STRINGVERSION
  LOCAL RESULTS:={};
  LOCAL RL;
  IF NN THEN
   RL:=1/NN;//DIAGNOSTIC ONLY:USUAL REAL
  ELSE
   RETURN {"DIVBY0"};
  TRANSIENT:=GETTRANSIENT(NN);
  WHATSLEFT:=exact(NN/(2^FR2*5^FR5));
  IF WHATSLEFT==1 THEN
   //AVOID STALL
   RETURN {TRANSIENT,{0,0},RL};//AVOID STALL
  //PRINT("BEFORE");
  //See http://www.hpmuseum.org/forum/thread-3212.html
  MO:=MultiplicativeOrder(WHATSLEFT,10);
  //PRINT("AFTER");
  NDIGITS:=TRANSIENT(1)+MO;//TRANSIENTLEN
  IF MO>ImpRELEN THEN
   RP:="(NaN)";
  END;//FOR NOW SHOW THE WEIRD OUTPUT
  RP:=iquo(1*10^NDIGITS,NN);
  //The string version asks for leading zeros I hoped
  //but no...pad it manually
  //ST:=format(RP,"s"+NDIGITS);
  ST:=ZEROS(NDIGITS-DIM(STRING(RP)))+RP;
  RESULTS:={TRANSIENT,{MO,ST},RL};//
  IF 0 THEN //DEBUG INFO
   PRINT();
   PRINT("Input Fraction: 1/"+NN+" = "+RL);
   PRINT("Whats Left: "+WHATSLEFT);
   PRINT("Multiplicative Order: "+MO);
   //PRINT("Length: "+{TRANSIENTLEN,MO});
   IF MO>12 THEN //EXPECT REPEATING PART TO GO WEIRD
    PRINT("MO>12: CAUTION");
   PRINT("TRANSIENT PART: "+IFTE(TRANSIENT(1),TRANSIENT(2),TRANSIENT(2)+" (none)"));
   PRINT(ST);
   PRINT(RESULTS);
  //RETURN RESULTS
  //TRANSIENTLEN=0 =NO TRANSIENT
  //MO=0 =NO REPEATING
  //MO>Imp: IGNORE REPEATING DIGITS
  //RL:REAL JUST FOR COMPARISON
  RETURN RESULTS;
 EXPORT TESTS()
  LOCAL III,RR;
  FOR III FROM 1 TO 1000  DO
   //RECT_P();
   //TEXTOUT_P(III,0,120);
    //WAIT(2);
   TESTED(0):=III;
   RR:=ReDIGITS(III);
 EXPORT REDECIMALS()
  PRINT(CRID);
  //RECT_P();
  PRINT(TEVAL(TESTS));
Note: A comparable CAS implementation could improve ranges handled.
Update: 99989 crashes the Android emulator.
01-24-2018, 07:21 PM
RE: Repeating Decimals / Recurring Decimals
Version 0.3 includes an optimised MultiplicativeOrder (base 10) and outputs a string with the recurring part annotated with an underscore (selectable).
 LOCAL CRID:="REPEATING DECIMAL (PPL) V 0.3 \nCode: StephenG1CMZ";
 LOCAL ALGM:="Following Joe Horn's algorithm: http://www.hpmuseum.org/forum/thread-9919.html";
 //This implement yields useful results but
 //NB Sometimes the leading 0. is included in the output
 //but sometimes it is not...EG NN=14 Why?
 LOCAL ImpRELEN:=12;//(EMPIRICAL 12-15) 16 IS WRONG
 LOCAL FR2,FR5;//GLOBAL RETURN
 EXPORT TRANSIENTLEN;//Length of Transient
 EXPORT RELEN;//Length of Recurring Digits/Repeating Digits
  //^Len == Decimal Digits Only
 EXPORT USCORE:="_";//CHANGE TO EMPTY STRING IF YOU WISH TO EVAL THE STRING
 EXPORT DECSEP:=".";//DECIMAL SEPARATOR (USED WHEN TRANSIENTLEN=0,IDEALLY GET FROM SYSTEM)
 EXPORT TESTED:={};
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 ZEROS(NN)
  IF NN>0 THEN
  RETURN "";
 EXPORT MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 EXPORT MultiplicativeOrder10(WL)
 //WL: WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  LOCAL LST:={};//POSSIBLES TO CHECK
  IF WL≠1 THEN
   //Get possibles
   LST:=mat2list(idivis(euler(WL)));
   //Search possiblesfor a match
   WHILE AP<SIZE(LST) AND NOTFND DO
    AP:=AP+1;
    IF powmod(10,LST(AP),WL)==1 THEN
     NOTFND:=0;//FOUND
    END;//IF
   END;//LOOP
  END;//IF
  //Return match
  //Return 0 if WL=1 or no match
  RETURN IFTE(NOTFND,0,LST(AP));//TBC
 EXPORT GetTransient(NN)
  LOCAL TRANSIENTPART;
  TRANSIENTLEN:=MaxFactor25(NN);
  IF TRANSIENTLEN THEN
   TRANSIENTPART:=TRUNCATE((1/NN),TRANSIENTLEN);
  ELSE
   //DIVBY0 TBD
   TRANSIENTPART:=IP(1/NN)+DECSEP;
  RETURN TRANSIENTPART;
 //NN INTEGER
  LOCAL WHATSLEFT;
  LOCAL RP,NDIGITS;
  LOCAL ST:="";//STRINGVERSION
  LOCAL RESULTS:={};
  LOCAL RL;
  IF NN THEN
  ELSE
   RETURN {"DIVBY0"};
  TRANSIENTPART:=GetTransient(NN);
   RETURN TRANSIENTPART;//AVOID STALL
  //RELEN:=MultiplicativeOrder(WHATSLEFT,10);
  RELEN:=MultiplicativeOrder10(WHATSLEFT);
  NDIGITS:=TRANSIENTLEN+RELEN;
  IF RELEN>ImpRELEN THEN
   //TBD: A better test might be to search for ᴇ in the string
   ST:="(NaN)";//Implementation limit:BAD IQUO?
  RP:=iquo((1*10^NDIGITS),NN);
  ST:=ST+MID(ZEROS(NDIGITS-DIM(STRING(RP)))+RP,TRANSIENTLEN+1);
  RESULTS:=TRANSIENTPART+USCORE+ST;
  //RESULTS:={{TRANSIENTLEN,TRANSIENTPART},{RELEN,ST},RL};//
   PRINT();
   PRINT("Multiplicative Order: "+RELEN);
   //PRINT("Length: "+{TRANSIENTLEN,RELEN});
   IF RELEN>12 THEN //EXPECT REPEATING PART TO GO WEIRD
    PRINT("RELEN>12: CAUTION");
   PRINT("TRANSIENT PART: "+IFTE(TRANSIENTLEN,TRANSIENTPART,TRANSIENTPART+" (none)"));
   PRINT(ST);
   PRINT(RESULTS);
  //RETURN RESULTS
  //Return a formatted string
  //(Relevant Lengths are returned globally)
  RETURN RESULTS;
 EXPORT Recurring(NN)
  RETURN ReDIGITS(NN);
 //Some call them Recurring
 //Some call them Repeating
 EXPORT Repeating(NN)
 EXPORT TESTS()
  LOCAL III,RR;
   //RECT_P();
    //WAIT(2);
   TESTED(0):=III;
   RR:=ReDIGITS(III);
 EXPORT SHOWME()
  LOCAL II;
  FOR II FROM 1 TO 1000 DO
    RECT_P();
    TEXTOUT_P(II,0,20);
    TEXTOUT_P(ReDIGITS(II),0,40);
    WAIT;
 EXPORT REDECIMALS()
  ABOUT;
  //PRINT((ReDIGITS(301)));
  //WAIT;
  //RECT_P();
Note there is a bug with the string formatting...Sometimes it includes the integer part, sometimes not.
01-26-2018, 11:02 PM (This post was last modified: 01-27-2018 07:27 PM by StephenG1CMZ.)
Version 0.4 has cosmetic improvements and help. It adds a CAS variable which show more digits, but I have yet to find out how use that in PPL - Whenever I try to turn it into a string, it turns into a real instead.
(Update: I have found the required syntax to do that now, so expect another release soon.)
 LOCAL CRID:="REPEATING DECIMAL V 0.4 \n©2018 StephenG1CMZ";
 LOCAL ImpRELEN:=12;//(EMPIRICAL)
 LOCAL ImpTransientLEN:=12;//(EMPIRICAL)
 //Should NDIGITS>12 fail?: not tested.
 EXPORT TransientLEN;//Length of Transient
 EXPORT RepetendLEN;//Length of Recurring Digits/Repeating Digits
 EXPORT TESTED:=0;
 LOCAL STNAN:="(NaN)";
 MultiplicativeOrder10();//FORWARD
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT("Recurring/Repeating: Given integer NN, return a string of its real reciprocal with _ marking any recurring digits.");
  PRINT("ShowMe: Shows a range of values.");
  PRINT(" ");
  PRINT("Variables In: Strings DECSEP,USCORE ");
  PRINT("Variables Out: RepetendLEN, TransientLEN");
  PRINT("CAS: temporary variable shows more digits: Can this be used from PPL?");
  PRINT("{Repetend,Transient}>12 digits: NaN implemented (PPL Limit).");
 ZEROS(NN)
  IF NN>0 THEN
  RETURN "";
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 //NOTE: THIS IS CALLED BY Recurring/Repeating.
  TransientLEN:=MaxFactor25(NN);
  IF TransientLEN THEN
   IF TransientLEN>12 THEN
    //EG NN=8192
    //MSGBOX("Caution:TransientLEN= "+TransientLEN);//FIX TBC
    TRANSIENTPART:="(NaN)";//IP(1/NN);//AVOID TRUNCATE
   ELSE
    TRANSIENTPART:=TRUNCATE((1/NN),TransientLEN);//TRUNCATE BREAKS AT 13
  ELSE
   IF NN==0 THEN
    RETURN STNAN+"DIVBY0";
 ReDIGITS (NN )
 //NN INTEGER
  LOCAL STR:="";
  LOCAL WHATSLEFT;
  LOCAL RP,NDIGITS;
  LOCAL RESULTS:={};
  LOCAL RL;
  IF NN THEN
  ELSE
   //RETURN TRANSIENTPART;//AVOID STALL
  //RepetendLEN:=MultiplicativeOrder(WHATSLEFT,10);
  RepetendLEN:=MultiplicativeOrder10(WHATSLEFT);
  NDIGITS:=TransientLEN+RepetendLEN;
  IF RepetendLEN THEN
   IF RepetendLEN>ImpRELEN THEN
    ST:=STNAN;//Implementation limit:BAD IQUO?
   //MSGBOX({NDIGITS,NN});
  //MSGBOX(RP);
   CAS("temporary:=iquo((1*10^NDIGITS),NN)");
   //CAS("PRINT(temporary)");
   //PRINT(STR);
   ST:=ST+MID(ZEROS(NDIGITS-DIM(STRING(temporary)))+temporary,TransientLEN+1);
   PRINT();
   PRINT("Multiplicative Order: "+RepetendLEN);
   //PRINT("Length: "+{TransientLEN,RepetendLEN});
   IF RepetendLEN>12 THEN //EXPECT REPEATING PART TO GO WEIRD
    PRINT("RepetendLEN>12: CAUTION");
   PRINT(ST);
   PRINT(RESULTS);
  //RETURN RESULTS
  RETURN RESULTS;
 EXPORT Show1(NN)
    RECT_P();
    TEXTOUT_P(CRID,0,0,3);
    //TEXTOUT_P(ALGM,0,15,1);
    TEXTOUT_P("Fraction,Reduced Fraction,Real,Decimal:",0,40);
    TEXTOUT_P("1/"+NN,0,60);
    TEXTOUT_P(CAS(1/NN)+" Reduced Fraction",0,80);
    TEXTOUT_P(IFTE(NN,(1/NN)+" Real",(STNAN+"DIVBY0")),0,100);
    //DEBUG;
    TEXTOUT_P(TRANSIENTPART+" Transient Part",0,140);
    TEXTOUT_P(Recurring(NN)+" Decimal",0,120);
    TEXTOUT_P("Has "+TransientLEN+" Transient digits & "+RepetendLEN+" Repetend digits",0,180);
    TEXTOUT_P("Variable CAS.temporary may show more",0,200);
    //TEXTOUT_P(CAS("temporary"),0,180);//doesnt work:PPL
    TEXTOUT_P("Esc to continue",0,220);
    IF RepetendLEN>ImpRELEN OR TransientLEN>ImpTransientLEN THEN
     //Highlight Implement NaN
     TEXTOUT_P("Imp"+STNAN,320/2,220,3,RGB(255,0,0));
    WAIT;
 EXPORT ShowMe(FIRST,LAST)
  LOCAL NN;
  FOR NN FROM FIRST TO LAST DO
    Show1(NN);
 EXPORT MultiplicativeOrder10(WhatsLeft)
 // WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
   LST:=mat2list(idivis(euler(WhatsLeft)));
    AP:=AP+1;
    IF powmod(10,LST(AP),WhatsLeft)==1 THEN
     NOTFND:=0;//FOUND
    END;//IF
   END;//LOOP
  END;//IF
  //Return match
 TESTS()
  LOCAL III,RR;
   //RECT_P();
    //WAIT(2);
   TESTED:=III;
   RR:=ReDIGITS(III);
 EXPORT REDECIMALS()
  ABOUT();
The implementation returns NaN if either the Transient part or Repetend exceed 12 digits.
01-31-2018, 09:10 AM
Version 0.5 is a much improved PPL program for showing transient parts and repetends of reciprocals. It has been rewritten to use CAS, enabling Transients and Repetends >12 digits to be handled, and is faster.
 LOCAL CRID:="REPEATING DECIMAL V 0.5 \n©2018 StephenG1CMZ";
 //This ppl implement yields useful results using CAS
 //to provide Transients and Repetends>12  digits
 //Interesting Test Values:
 //0,1,2,3,4,7,14,208,301,8192,8912
 //8192 FIX TBD
 LOCAL WHATSLEFT,NDIGITS;//GLOBAL RETURN
 EXPORT TESTED:=0;
 LOCAL DIVBY0:="(NaN)(DIVBY0)";
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT("GetLEN: Sets LENgth variables");
  PRINT("ShowReciprocal: Show Reciprocal");
  PRINT("ShowReciprocals: Shows a range of reciprocal values.");
  PRINT("CAS: temporary variable");
 ZEROS(NN)
 //Recursive is faster than using CAS
 //and can output more zeros than PPL
  //MSGBOX(NN);
  IF NN>0 THEN
  RETURN "";
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 EXPORT GetLEN(NN)
  //PRINT({TransientLEN,RepetendLEN});
  //DO NOT INCLUDE IP LENGTH
  RETURN {TransientLEN,RepetendLEN,NDIGITS};
 ReDIGITS (NN)
 //NN INTEGER
  LOCAL LST;//UNUSED
  LOCAL STR:="";
  LOCAL TRANSIENTPART,REPETEND,INTPART;
  LOCAL RESULTS;
  LOCAL DP;//DECIMAL PLACES
  LST:=GetLEN(NN);
  //GetDecimalPlaces
  //RP:=iquo((1*10^NDIGITS),NN);//works for repetends≤12digits:so use CAS
  ST:=CAS("string(temporary)");
  STR:=ZEROS(NDIGITS-DIM(ST));
  DP:=STR+ST;
  //GetRepetend
  REPETEND:=IFTE(RepetendLEN,MID(DP,TransientLEN+1),"");
  //GetTransientDecimalPlaces
  TRANSIENTPART:=IFTE(TransientLEN,LEFT(DP,TransientLEN),"");
  //Get IntegerPart
  INTPART:=IFTE(NN,(IP(1/NN)+DECSEP),DIVBY0);
  RESULTS:=INTPART+TRANSIENTPART+USCORE+REPETEND;
  //PRINT("RESULTS: "+RESULTS);
  //(Relevant Lengths are returned globally in ...LEN variables)
  RETURN RESULTS;
 GetTransient(NN)
 //NB Only when USCORE NOT EMPTY
  LOCAL ST:=ReDIGITS(NN);
  RETURN LEFT(ST,INSTRING(ST,USCORE));
 EXPORT ShowReciprocal(NN)
    LOCAL PXP:={0};
    RECT_P();
    TEXTOUT_P(IFTE(NN,(1/NN),(DIVBY0))+" Real",0,100);
    PXP(0):=TEXTOUT_P(TRANSIENTPART+" Transient Part",0,140);
    PXP(0):=TEXTOUT_P(Recurring(NN)+" Decimal",0,120);
    IF MAX(PXP)≥320 THEN //OFFSCREEN
     TEXTOUT_P("PRINT(Recurring(NN)) may show more digits",0,200,3,RGB(255,0,0));
    WAIT;
 EXPORT ShowReciprocals(FIRST,LAST)
  LOCAL NN;
    ShowReciprocal(NN);
 // WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
    AP:=AP+1;
     NOTFND:=0;//FOUND
    END;//IF
   END;//LOOP
  END;//IF
  //Return match
 TESTS(TESTN)
 //Perform some tests
  LOCAL III,RR;
  FOR III FROM 1 TO TESTN DO
   //RECT_P();
   DRAWMENU(III);
    //WAIT(2);
   TESTED:=III;
   RR:=ReDIGITS(III);
 EXPORT REDECIMALS()
  LOCAL TESTN:=1000;
  ABOUT();
  PRINT(TESTN+" reciprocals in "+TEVAL(TESTS(TESTN)));
  //HELP();
  //PRINT(Recurring(8912));
There are no specific limits other than unchecked list size/CAS integer limits.
In Show, a warning is given if screen size is exceeded, but such values can still be printed.
02-01-2018, 05:53 PM (This post was last modified: 02-01-2018 07:14 PM by StephenG1CMZ.)
Version 0.6
Show optimised. Note that the transient display assumes USCORE (underscore) is not empty.
Implementation Limits added (Some large values eg NN=1E14 exceed the limits of euler).
 LOCAL CRID:="REPEATING DECIMAL V 0.6 \n©2018 StephenG1CMZ";
 LOCAL ImpLimST:="MultiplicativeOrder10: Implementation Limit!\n";
 EXPORT TESTED:=0;
 EXPORT BigT:=0;
 EXPORT BigR:=0;
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT("Hint:To PRINT long strings,");
  PRINT("PRINT(a few bytes at a time)");
 ZEROS(NN)
  //MSGBOX(NN);
  IF NN>0 THEN
  RETURN "";
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 EXPORT GetLEN(NN)
 ReDIGITS (NN)
 //NN INTEGER
  LOCAL LST;//UNUSED
  LOCAL STR:="";
  LOCAL RESULTS;
  //Get Length
  //A possible optimisation:
  //Avoid recalc
  LST:=GetLEN(NN);
    //TBD:IF EXCESSIVE LENGTH RETURN NAN
  //GetDecimalPlaces
  DP:=STR+ST;
  //GetRepetend
  //Get IntegerPart
  RETURN RESULTS;
 GetTransient(NN)
 //NB RECALCULATES
 GetTransientToo(NN,ST)
 //Requires ST to supply digits an4 USCORE
    LOCAL PXP:={0};
    LOCAL DST;
    RECT_P();
    // COMMON REPRESENTATIONS
    //EARLY LENGTH
    //Note:This is recalculated in ReDIGITS
    GetLEN(NN);
    //Main Display
    DST:=Recurring(NN);
    //TEXTOUT_P("Has "+TransientLEN+" Transient digits & "+RepetendLEN+" Repetend digits",0,180);//IF NOT EARLY
    PXP(0):=TEXTOUT_P(DST+" Decimal",0,120);
    TRANSIENTPART:=GetTransientToo(NN,DST);
    WAIT;
  LOCAL NN;
    ShowReciprocal(NN);
 // WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
   IF TYPE(LST)≠TYPE({}) THEN //EMPIRICAL TEST
    //EG NN=1ᴇ14
    MSGBOX(ImpLimST+LST);
    RECT_P();//SAVE/RESTORE IDEALLY
    //PERHAPS RETURN AND HANDLE NAN INSTEAD
    //IF NOT CAUGHT powmod WILL FAIL
   IF TYPE(LST)==TYPE({}) THEN
     AP:=AP+1;
      NOTFND:=0;//FOUND
     END; //IF
    END;//LOOP
   END;//IF
  //Return match
  END;//VALID LST
 EXPORT TESTS(TESTN)
  LOCAL III,RR;
   //RECT_P();
   TESTED:=III;
   RR:=ReDIGITS(III);
   //Notethe biggest
   IF TransientLEN>BigT THEN
    BigT:=TransientLEN;
   IF RepetendLEN>BigR THEN
    BigR:=RepetendLEN;
   DRAWMENU(III,BigT,BigR);//MAX
   //DRAWMENU(III,TransientLEN,RepetendLEN);//CURRENT
 EXPORT REDECIMALS()
  LOCAL TESTN:=1000;
  ABOUT();
  //HEADLINE RATE: LARGER WILL BE SLOWER
  //PRINT(DIM(Recurring(29989)));
  //HELP();
Hope this is useful, although it is only implemented for reciprocals.
02-04-2018, 06:46 PM (This post was last modified: 02-05-2018 10:11 PM by StephenG1CMZ.)
Version 0.7 implements handling of fractions as well as reciprocals.
 LOCAL CRID:="REPEATING DECIMAL V 0.7 \n©2018 StephenG1CMZ";
 EXPORT TESTED:=0;
 EXPORT BigT:=0;
 EXPORT BigR:=0;
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT(CRID);
  PRINT(" Discovers characteristics of rational fractions that can be specified by an integer numerator and denominator.");
  PRINT(" ");
  PRINT("NB Fractions are input as 2 integers.\nDo not enter as Prime fractions.");
  PRINT(" ");
  PRINT("Scroll or Esc...");
  PRINT(" ");
  PRINT("API functions:");
  PRINT(" ");
  PRINT("GetLEN(fraction):");
  PRINT("Returns lengths and Sets LENgth variables.\nLengths exclude the IP and non-digits.");
  PRINT("GetLEN(1,3)={0,1}");
  PRINT(" ");
  PRINT("Recurring(fraction):");
  PRINT("Repeating(fraction):");
  PRINT("Returns a string of the real value with _ marking any recurring digits.");
  PRINT("Recurring(1,3)=0._3");
  PRINT(" ");
  PRINT("MultiplicativeOrder10(WhatsLeft):");
  PRINT("Implemented for base 10.");
  PRINT(" ");
  PRINT("Procedures:");
  PRINT(" ");
  PRINT("Show(fraction):");
  PRINT("Show Representations on_screen");
  PRINT("Show(1,3)");
  PRINT(" ");
  PRINT("ShowRange(Numer1,Numer2,Denom1,Denom2):");
  PRINT("Show Range of fractions one by one\nShowRange(1,0,3,0) = Show(1,3)");
  PRINT("ShowRange(1,2,3,4)=Show(1,3),Show(1,4),Show(2,3),Show(2,4)");
  PRINT(" ");
  PRINT("ShowReciprocals(Denom1,Denom2):");
  PRINT("Shows a range of reciprocal values one by one.\nShowReciprocals(3,0)=Show(1,3)");
  PRINT("ShowReciprocals(1,3)=Show(1,1),Show(1,2),Show(1,3)");
  PRINT("");
  PRINT(" ");
  PRINT("Hint: To PRINT long strings,");
 //STANDARD ROUTINES
 DIGITSNEEDED(NN)
 //DIGITS NEEDED FOR IP
 //EXCLUDES SIGN POINT SEPARATOR
  IP(LOG(MAX(1,ABS(NN))))+1;
 ZEROS(NN)
  //MSGBOX(NN);
  IF NN>0 THEN
  RETURN "";
 //END STANDARD
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 EXPORT GetLEN(NumerN,DenomN)
 //Get TransientLEN,RepetendLEN,NDIGITS
 //These lengths are decimal places and exclude IPLEN
 //0 DENOMINATOR: RETURN {0,0,0}
  LOCAL RedNUMER,RedDENOM;
  IF DenomN THEN
   //Step 0: Reduce Fraction
   RedNUMER:=CAS("numer(NumerN/DenomN)");
   RedDENOM:=CAS("denom(NumerN/DenomN)");
   IF RedNUMER≠NumerN OR RedDENOM≠DenomN THEN
    RETURN GetLEN(RedNUMER,RedDENOM);
   //Continue
   TransientLEN:=MaxFactor25(DenomN);
   WHATSLEFT:=exact(DenomN/(2^FR2*5^FR5));
  ELSE //DIVBY0
   TransientLEN:=0;
   RepetendLEN:=0;
   NDIGITS:=0;
 ReDIGITS (NUMER,NN)
 //Determine Digits of the fraction (NUMER/NN)
 //NUMERATOR INTEGER
 //DENOMINATOR INTEGER
 //DENOMINATOR 0 RETURNS NAN
  LOCAL LST;//UNUSED
  LOCAL STR:="";
  LOCAL RESULTS;
  LOCAL IPLEN;
  //Step 0: reduce fraction
  RedNUMER:=CAS("numer(NUMER/NN)");
  RedDENOM:=CAS("denom(NUMER/NN)");
  IF RedNUMER≠NUMER OR RedDENOM≠NN THEN
   RETURN ReDIGITS(RedNUMER,RedDENOM);
  //Continue...
  //Get Length
  //Avoid recalc
  LST:=GetLEN(NUMER,NN);
  //GetDecimalPlaces
  CAS("temporary:=iquo(((NUMER*10^NDIGITS),NN)");
  //MSGBOX(ST);
  DP:=STR+ST;
  INTPART:=IFTE(NN,(IP(NUMER/NN)+DECSEP),DIVBY0);
  //IF NUMER==1 THEN
   //RECIPROCAL:iquo returns decimal places only
  IF NN AND NUMER≠1 THEN
   //FRACTION: iquo returns IP and decimals with no point
   IPLEN:=DIGITSNEEDED(IP(NUMER/NN));//LEN OF IP
   //INTPART:=LEFT(DP,IPLEN)+DECSEP; //IP
   DP:=MID(DP,IPLEN+1); //DP
  //GetRepetend
  //Get IntegerPart
  RETURN RESULTS;
 EXPORT Recurring(NumerN,DenomN)
  RETURN ReDIGITS(NumerN,DenomN);
 EXPORT Repeating(NumerN,DenomN)
 GetTransient(NUMER,NN)
 //NB RECALCULATES
  LOCAL ST:=ReDIGITS(NUMER,NN);
 GetTransientToo(NUMER,NN,ST)
 EXPORT Show(NumerN,DenomN)
    LOCAL PXP:={0};
    LOCAL DST;
    LOCAL RedDENOM;
    RECT_P();
    TEXTOUT_P(NumerN+"/"+DenomN,0,60);
    TEXTOUT_P(CAS(NumerN/DenomN)+" Reduced Fraction",0,80);
    TEXTOUT_P(IFTE(DenomN,(NumerN/DenomN),(DIVBY0))+" Real",0,100);
    //EARLY LENGTH
    GetLEN(NumerN,DenomN);
    //Main Display
    DST:=Recurring(NumerN,DenomN);
    TRANSIENTPART:=GetTransientToo(NumerN,DenomN,DST);
    WAIT;
 EXPORT ShowRange(Numer1,Numer2,Denom1,Denom2)
  LOCAL II,JJ;
  FOR II FROM Numer1 TO MAX(Numer2,Numer1) DO
   FOR JJ FROM Denom1  TO MAX(Denom2,Denom1) DO
    Show(II,JJ);
  LOCAL NN;
  FOR NN FROM FIRST TO MAX(LAST,FIRST) DO
   Show(1,NN);
 // WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
    //EG NN=1ᴇ14
     AP:=AP+1;
      NOTFND:=0;//FOUND
     END; //IF
    END;//LOOP
   END;//IF
  //Return match
  END;//VALID LST
 EXPORT TESTS(TESTN)
  LOCAL III,RR;
   //RECT_P();
   TESTED:=III;
   RR:=ReDIGITS(2,III);
   //Note the biggest
    BigT:=TransientLEN;
    BigR:=RepetendLEN;
 EXPORT REDECIMALS()
  LOCAL TESTN:=1000;
  ABOUT();
  PRINT(TESTN+" fractions in "+TEVAL(TESTS(TESTN)));
  //PRINT(DIM(Recurring(1,29989)));
  //HELP();
Update: use with care.
On the Android, this implementation can be problematic with larger values such as 2/16384.
Sometimes it seems to work and can return useful results, but after a Bad Argument error is reported, problems persist in the running of other programs until the calculator (not the mobile) is switched off.
02-06-2018, 11:24 PM (This post was last modified: 02-07-2018 07:47 PM by StephenG1CMZ.)
I have noticed an issue with the step 0 fraction reduction as I have implemented it in V0.7.
In V0.6, 1/1E14 would be processed by the algorithm (no reduction being implemented).
An error message would issue from Multiplicateorder10 as implementation limits are exceeded.
In V0.7, 1/1E14 is reduced to 1E-14/1 and non-integer numerator is processed, resulting in a NaN with no error message from MultiplicativeOrder10 seen.
Potentially, there might be other values which MultiplicateOrder10 might have handled, but which are not being processed because the reduction step is introducing unexpected non-integer values.
02-07-2018, 08:02 PM
Note that some long repetends incorrectly return all zeros instead of the correct digits (the reported length is correct). If you see a value with just zeros assume it is incorrect.
02-08-2018, 09:03 PM (This post was last modified: 02-08-2018 10:10 PM by StephenG1CMZ.)
Version 0.8
Improved handling of implementation limitations.
Improved user interface shows more digits on-screen and allows long strings not to be generated.
 LOCAL CRID:="REPEATING DECIMAL V 0.8 \n©2018 StephenG1CMZ";
 LOCAL ImpPRINT:=2000;//PRINT LIMIT <2K
 LOCAL ImpSTRING:=64000;//LIMIT VALUE TBC
 EXPORT WAITS:=0;
 EXPORT ImpRELEN:=ImpSTRING;//MAX LEN TO GENERATE
 EXPORT TESTED:=0;
 EXPORT BigT:=0;
 EXPORT BigR:=0;
 LOCAL DIVBY0:=STNAN+"{0}";//DIVBY0
 LOCAL NOTINT:=STNAN+"(NotInteger)";
 LOCAL STNANImp:=STNAN+"(Imp)";//Implemenation Limit
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT(CRID);
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT("[Esc] to continue to next page");
  PRINT("[View] more digits");
  PRINT("Show(1,3)");
  PRINT(" ");
  PRINT(" ");
  PRINT("");
  PRINT("Variables In: (Selectable by user @Home)");
  PRINT("ImpRELEN: Recurring LEN limit");//Limit to manageable length
  PRINT("String USCORE: Underscore ");
  PRINT("WAITS: Show WAIT time (0=Esc)");
  PRINT(" ");
  PRINT("Variables Out:");
  PRINT("RepetendLEN, TransientLEN");
  PRINT(" ");
  PRINT("Known Limitations:");
  PRINT("Numbers beyond about 1/12109:");
  PRINT("Repetend digits incorrectly show just 0-s (LEN OK)");
  PRINT(" ");
  PRINT(" ");
  PRINT("Interesting Test Values:");
  PRINT("{1/: 0,1,2,3,4,7,14,208,301,8192}");
  PRINT("{1/: 29989}//WRONG}");
  PRINT("{1/: 3^15}//CRASH AVOIDED");
  PRINT("{2/: 16384}")
 //STANDARD ROUTINES
 DecSepNow()
 //RETURN current system decimal separator
 //From the forum
  RETURN IFTE((HSeparator MOD 9)<4,".",",");
 //QUERY:WOULD TAKING LOGS OF NUMERATOR AND DENOMINATOR AND SUBTRACTING
 //IMPROVE RANGE OR PRECISION TBD
 DIGITSNEEDED(NN)
 ZEROS(NN)
  //MSGBOX(NN);
  IF NN>0 THEN
  RETURN "";
 //END STANDARD
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
  LOCAL GD;
  IF DenomN THEN
   GD:=gcd(NumerN,DenomN);
   RedNUMER:=NumerN/GD;
   RedDENOM:=DenomN/GD;
   //Continue
   TransientLEN:=MaxFactor25(RedDENOM);
   WHATSLEFT:=exact(RedDENOM/(2^FR2*5^FR5));
  ELSE //DIVBY0
   TransientLEN:=0;
   RepetendLEN:=0;
   NDIGITS:=0;
 ReDIGITS (NUMER,NN)
 //NUMERATOR INTEGER
 //NEGATIVES OK
 //DENOMINATOR 0: RETURN NAN
 //NONINTEGER: UNCHECKED
  LOCAL GD;
  LOCAL LST;//UNUSED
  LOCAL STR:="";
  LOCAL RESULTS;
  LOCAL IPLEN;
  //MSGBOX({NUMER,NN});
  //GUARDS
  IF NN==0 THEN
   RETURN DIVBY0;
  IF FP(NUMER) OR FP(NN) THEN
   RETURN NOTINT+STRING({NUMER,NN});//PARAMETERS NOT INTEGER
  IF (NUMER/NN)<0 THEN
   RETURN "−"+ReDIGITS(ABS(NUMER),ABS(NN));
  //OK
  GD:=gcd(NUMER,NN);
  RedNUMER:=NUMER/GD;
  RedDENOM:=NN/GD;
  //Continue...
  //Get Length
  //Avoid recalc
  LST:=GetLEN(RedNUMER,RedDENOM);
  //IF EXCESSIVE LENGTH RETURN NAN
  IF NDIGITS>MIN(ImpRELEN,ImpSTRING-9) THEN //−9-ALLOW FOR DECSEP ETC
   //STRING:TOO LONG TO GENERATE
   //RELEN:USER LIMIT(TOO LONG/SLOW FOR USER)
   RETURN STNANImp;
  //GetDecimalPlaces
  CAS("temporary:=iquo(((RedNUMER*10^NDIGITS),RedDENOM)");
  //MSGBOX(ST);
  DP:=STR+ST;
  //GetINTEGERPART
  INTPART:=IFTE(RedDENOM,(IP(RedNUMER/RedDENOM)+DecSepNow()),DIVBY0);//THIS DIVBY IS GUARDED
  //IF NUMER==1 THEN
  IF RedNUMER≠1 THEN //NN
   IPLEN:=DIGITSNEEDED(exact(RedNUMER/RedDENOM));//LEN OF IP
  //GetRepetend
  //Imp:Sometimes the string contains source
  IF INSTRING(RESULTS,"M") THEN
   RESULTS:=STNANImp+RESULTS;//MARK BAD RESULT
  RETURN RESULTS;
 //NB RECALCULATES
    LOCAL PXP:={0};
    LOCAL DST;
    LOCAL RedDENOM;
    LOCAL KK,LST;
    RECT_P();
    TEXTOUT_P(CAS(NumerN/DenomN)+" Reduced Fraction",0,80);//NEEDS FIXING
    //EARLY LENGTH
    LST:=GetLEN(NumerN,DenomN);
    //Main Display
    IF INSTRING(DST,"00000000000000") THEN
     //Loss Of significance suspected
     TEXTOUT_P(" ! Check Possible Loss Of Significance !",0,200,3,RGB(255,0,0));
     TEXTOUT_P("[View]",320*(4/6),220,3,RGB(255,0,0));
    TEXTOUT_P(IFTE(WAITS>0,"Wait...","[Esc]"),320*(5/6),220,3);
    KK:=WAIT(WAITS);
    IF KK==9 THEN //VIEW KEY
     PRINT();
     PRINT(NumerN+"/"+DenomN);
     PRINT(LST);
     PRINT(MID(DST,1,ImpPRINT));
     IF DIM(DST)>ImpPRINT THEN
      PRINT("PRINT Unable");//Or:Loop
     //WAIT(WAITS);
    RETURN DST;
 //Show range one by one
  LOCAL II,JJ;
    Show(II,JJ);
  LOCAL NN;
   Show(1,NN);
 // WHATSLEFT
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
    //EG NN=1ᴇ14
     AP:=AP+1;
      NOTFND:=0;//FOUND
     END; //IF
    END;//LOOP
   END;//IF
  //Return match
  END;//VALID LST
 EXPORT TESTS(TESTN)
  LOCAL III,RR;
   //RECT_P();
   TESTED:=III;
   //Note the biggest
    BigT:=TransientLEN;
    BigR:=RepetendLEN;
 EXPORT REDECIMALS()
  LOCAL TESTN:=1000;
  ABOUT();
  //HELP();
Note that some long repetends incorrectly show all zeros. These will be highlighted in Show but do not raise a NaN.
02-10-2018, 11:15 PM (This post was last modified: 02-11-2018 11:38 PM by StephenG1CMZ.)
Version 0.9 fixes a bug caused by "exact", introduced in V0.8. Thanks for spotting that.
Error MSGBOX is improved (using an AFile to save/restore the screen).
 LOCAL CRID:="REPEATING DECIMAL V 0.9 \n©2018 StephenG1CMZ";
 EXPORT RedNUMER,RedDENOM;
 EXPORT WAITS:=0;
 EXPORT TESTED:=0;
 EXPORT BigT:=0;
 EXPORT BigR:=0;
 LOCAL FL:="ZTmpMESSAGEBOX";
 EXPORT ABOUT()
  PRINT();
  PRINT(CRID);
  PRINT(ALGM);
 EXPORT HELP()
  PRINT();
  PRINT(CRID);
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT("Key [Esc] to continue to next page");
  PRINT("Key [View] for more digits");
  PRINT("(Do not tap)");
  PRINT("Show(1,3)");
  PRINT(" ");
  PRINT(" ");
  PRINT("");
  PRINT(" ");
  PRINT("RepetendLEN, TransientLEN//Lengths");
  PRINT("RedNUMER, RedDENOM//Reduced");
  PRINT("(set by GetLEN,Recurring,Repeating)");
  PRINT(" ");
  PRINT("Negative inputs may error.");
  PRINT(" ");
  PRINT(" ");
  PRINT("{1/: 1ᴇ14}//Imp");
  PRINT("{1/: 3^15}//ImpCRASH AVOIDED");
  PRINT("{2/: 3}");
  PRINT("{2/: 16384}");
  PRINT("{123/208}");
 //STANDARD ROUTINES
 DecSepNow()
 //From the forum
 DIGITSNEEDED(NN)
  //RETURN IP(LOG(MAX(1,ABS(NN))))+1;//PORTABLE
  RETURN MAX(0,(XPON(NN)))+1;//PRIME XPON=BASE 10
 SCR_GET()
  G0:=AFiles(FL)
 SCR_PUT()
  AFiles(FL):=G0;
 ZMSGBOX(ST,OKC)
  SCR_PUT();
  OKC:=MSGBOX(ST,OKC);
  SCR_GET();
  RETURN OKC;
 ZEROS(NN)
  //MSGBOX(NN);
  IF NN>0 THEN
  RETURN "";
 //END STANDARD
 MaxFactor25(NN)
  LOCAL MAXFACTR:=0;
  FR2:=0; FR5:=0;
  LP:=POS(LSTB,2);
  IF LP THEN
  LP:=POS(LSTB,5);
  IF LP THEN
 //NEGATIVES:UNCHECKED
  LOCAL GD;
  IF DenomN THEN
   //Continue
  ELSE //DIVBY0
   TransientLEN:=0;
   RepetendLEN:=0;
   NDIGITS:=0;
  //NOTE: 0,0 IS OFTEN SUGGESTIVE OF AN ERROR
  //BUT IS ALSO RETURNED BY 1/1
  //SO MAYBE USE AN ERRORFLAG?
 ReDIGITS (NUMER,NN)
 //NUMERATOR INTEGER
 //NEGATIVES:ATTEMPTED BUT RAISE ERROR
 //NONINTEGER: RETURN NAN
  LOCAL GD;
  LOCAL LST;//UNUSED
  LOCAL STR:="";
  LOCAL RESULTS;
  LOCAL IPLEN;
  //GUARDS
  IF NN==0 THEN
   RETURN DIVBY0;
  IF NUMER<0 OR NN<0 THEN
   RESULTS:=ReDIGITS(ABS(NUMER),ABS(NN));
   RETURN IFTE((NUMER/NN)<0,"−"+RESULTS,RESULTS);
  //OK
  GD:=gcd(NUMER,NN);
  RedNUMER:=NUMER/GD;
  RedDENOM:=NN/GD;
  //Continue...
  //Get Length
  //Avoid recalc
   RETURN STNANImp;
  //GetDecimalPlaces
  //MSGBOX(ST);
  DP:=STR+ST;
  //GetINTEGERPART
  //IF NUMER==1 THEN
  //DEBUG;
   IPLEN:=DIGITSNEEDED((IP(RedNUMER/RedDENOM)));//LEN OF IP
  //GetRepetend
  RETURN RESULTS;
 //NB RECALCULATES
    LOCAL PXP:={0};
    LOCAL DST;
    LOCAL KK,LST;
    RECT_P();
    //EARLY LENGTH
    TEXTOUT_P(RedNUMER+"/"+RedDENOM+" Reduced Fraction",0,80);
    //Main Display
    KK:=WAIT(WAITS);
     PRINT();
     PRINT(LST);
     //WAIT(WAITS);
    RETURN DST;
  LOCAL II,JJ;
    Show(II,JJ);
  LOCAL NN;
   Show(1,NN);
 // WHATSLEFT
  LOCAL OKC:=0;
  LOCAL AP:=0;
  LOCAL NOTFND:=1;
  IF WhatsLeft≠1 THEN
   //Get possibles
    //EG NN=1ᴇ14
    OKC:=ZMSGBOX((ImpLimST+LST),OKC);
     AP:=AP+1;
      NOTFND:=0;//FOUND
     END; //IF
    END;//LOOP
   END;//IF
  //Return match
  END;//VALID LST
 EXPORT TESTS(TESTN)
  LOCAL III,RR;
   //RECT_P();
   TESTED:=III;
   //Note the biggest
    BigT:=TransientLEN;
    BigR:=RepetendLEN;
 TESTD()
  LOCAL II;
   DIGITSNEEDED(123.4);
 EXPORT REDECIMALS()
  LOCAL TESTN:=1000;
  ABOUT();
  //HELP();
Some long repetends continue to incorrectly show all zeros.
Negative fractions may now cause a MultiplicativeOrder10 error message
Update: Some values are incorrect...
