AMORT command giving incorrect syntax error
03-15-2014, 08:49 PM
Hi all,
I am getting an error message every time I use the AMORT command on the spreadsheet App. This is curious because by typing the exact same command on the Emulator, the command works just fine. Could a change in my settings be causing the issue? If so, are there any troubleshooting steps that you could recommend?
[Image: Ftnd3NZ.png]
Works on the emulator, does not work on the actual calculator.
Thanks
03-16-2014, 03:41 AM
RE: AMORT command giving incorrect syntax error
Strange.
I've put it on the list of things to investigate.
TW
03-16-2014, 06:31 AM
(03-16-2014 03:41 AM)Tim Wessman Wrote:  Strange.
Thanks, Tim. I get "Error: Invalid input" every time on the calculator while the Emulator always gives me the amortization table as expected.
03-17-2014, 06:36 AM
the syntax has changed since the first version (from memory).
try removing the A2 and the ""...
your emulator and FW probably have a different revision.
03-17-2014, 06:53 AM
(03-17-2014 06:36 AM)cyrille de brébisson Wrote:  Hello,
Hi Cyrille - thanks for your response. I removed the A2, removed the "" and still got the same error. I tried removing just the A2 and then just the "" as well, but I get the same error message.
Any thoughts?
03-18-2014, 06:10 AM
hello,
My mistake, just remove the "", leave the A2...
syntax is AMORT(range, n, i, pv, pmt)
cyrille
