Fun with Numbers: The Pan-Prime-Digit Cube Hypothesis
07-30-2017, 06:17 AM
A "pan-prime-digit number" is a natural number containing all four prime digits (2, 3, 5, and 7) in any order, one or more times each, but no other digits. The smallest pan-prime-digit number is 2357, which also happens to be a prime number, but there are obviously infinitely many pan-prime-digit numbers, and probably infinitely many prime ones. I'm pretty sure that the smallest pan-prime-digit number which is a perfect SQUARE is 23377225 (equal to 4835^2). There are probably infinitely many pan-prime-digit squares.
However, it is my hypothesis that there is ONLY ONE pan-prime-digit CUBE. I would be delighted beyond words if anybody could either prove (mathematically) or disprove (by counterexample) this hypothesis. Needless to say, finding the one known pan-prime-digit cube is left as a mini programming challenge. This posting appears in the "Not remotely" forum because no current HP programmable calculator is fast enough to find the number in a reasonable amount of time; it's surprisingly large. <0|ɸ|0> -Joe- |
07-30-2017, 04:38 PM
RE: Fun with Numbers: The Pan-Prime-Digit Cube Hypothesis
Perhaps the following url's ...
a) Prime Curios!- 7 b) Prime Curios!- 89 c) An ancient Greek algorithm could reveal all-new prime numbers ... inspire / edify the pure math curious / challenged (myself included). Interesting read, Joe, thanks! BEST! SlideRule |
08-01-2017, 12:51 AM
I think I have found a proof, but the margins here are to small to contain it.
08-01-2017, 03:24 AM
Ah, but then you miss out on the Millennium Prize $1,000,000 award.
08-02-2017, 05:29 PM
(This post was last modified: 08-02-2017 07:56 PM by Luigi Vampa.)
After three days trying to prove the 'Horn Conjecture', I throw the towel ;0) I think I will devote myself to implement symplectic integration in Free42, in order to start searching for Planet Nine. The latter is going to be much easier for good >D
Saludos Saluti Cordialement Cumprimentos MfG BR + + + + + Luigi Vampa + Free42 HuaweiP10 '<3' I + + + |
08-06-2017, 09:47 AM
To avoid suspense: Horn's Conjecture is WRONG.
After prolonged hesitation & cogitation I decided to join the throng of adepts attempting to solve the question of Joe's conjecture. First some general observations: 1 The ancient Greeks have very little to say: they were not interested in digits in a positional representation of numbers, they were interested in the properties of numbers; 2 The proof below exceeds the limits of the margin, nevertheless I will publish the complete proof to expose it to the court of my peers, superiors & inferiors; 3 I am not interested in financial gain. An approach is to convert a problem in multiplicative number theory (structure of x^3) to one of additive number theory (sum of consecutive odd integers). For integer input N the programme below returns N & a list of consecutive odd integers that sum to n^3: Code:
& similarly hopeless is a proof in the traditional sense, as base 10 representation of a number tells us more about 10 than of the number represented. Number theory speaks of the properties of numbers, eg 3153023022 base 7 is an odd number, & this remains true if converted to base 10 or any base. So I arrived at a heuristic proof. What is the probability of there being exactly one cube, call it H, with decimal digits exclusively 2,3,5,7 & each of these digits appearing in the representation? Difficult to say, but surely very small. The probability can be further diminished by adding that Joe found H. That Joe found H amongst the infinitude of cubes can only indicate that there must be a large number of cubes with the required property. Indeed, using the maximum likelihood hypothesis, the greatest probability of Joe finding H occurs when there is an infinity of such cubes. Proving, to all intents & purposes, that there is an infinity of the proposed cubes. QED |
08-06-2017, 09:48 PM
(08-06-2017 09:47 AM)Gerald H Wrote: To avoid suspense: Horn's Conjecture is WRONG. ... I arrived at a heuristic proof. See my comments inserted above, inside [ square ] brackets. As mentioned in the original posting, a counterexample would suffice to disprove the conjecture. The above rationale explains why the conjecture is probably false, but it does not disprove it. FWIW, if the above were a valid proof, then it would also prove the existence of infinitely many perfect square repunits, since 1 itself is certainly one such. But there are no others. Therefore the "proof" is invalid. QED. <0|ɸ|0> -Joe- |
08-06-2017, 10:06 PM
(This post was last modified: 08-06-2017 10:06 PM by SlideRule.)
ALL
for the Latin challenged; QED = quod erat demonstandum = thus it has been demonstrated. BEST! SlideRule |
08-07-2017, 12:58 AM
(This post was last modified: 08-07-2017 12:59 AM by rprosperi.)
(08-06-2017 10:06 PM)SlideRule Wrote: QED = quod erat demonstandum = thus it has been demonstrated. Funny, I was taught it means "Quit, Everything is Done" or "Quit, Explanation is Done" --Bob Prosperi |
08-07-2017, 03:38 AM
Singer-songwriter Thomas Dolby's 1988 song "Airhead" includes the lyric, "Quod erat demonstrandum, baby," referring to the self-evident vacuousness of the eponymous subject; and in response, a female voice squeals, delightedly, "Oooh... you speak French!"
— excerpt from the Wikipedia article about "Q.E.D." <0|ɸ|0> -Joe- |
08-07-2017, 07:14 AM
(08-07-2017 03:38 AM)Joe Horn Wrote: Singer-songwriter Thomas Dolby's 1988 song "Airhead" includes the lyric, "Quod erat demonstrandum, baby," referring to the self-evident vacuousness of the eponymous subject; and in response, a female voice squeals, delightedly, "Oooh... you speak French!" Oh, my poor lingua mater! :) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
08-07-2017, 07:56 AM
I draw hope from the "Too soon".
Still working at it. |
08-07-2017, 10:33 AM
Following the same logic:
By the prime number theorem, the one that gives the asymptotic distribution of prime numbers, the probability that any positive integer less than N is a prime number goes to 0 (as N goes to infinity). Hence, the probability of any positive integer being a prime number is zero. Therefore there are no prime numbers other than the ones that have already been discovered. QED. |
08-07-2017, 10:50 AM
"no current HP programmable calculator is fast enough to find the number in a reasonable amount of time"
Are you sure? Perhaps you are right, but there are some obvious ways to cut down the number of required calculations quite a bit, as compared to a naive brute force attack. E.g. you could calculate the number of different values of n^3 mod 1000 (and then mod 10^6, then mod 10^9) that only contain the required digits. I would expect that that could narrow down the search quite a bit... |
08-07-2017, 07:09 PM
(This post was last modified: 08-08-2017 09:14 PM by David Hayden.)
(08-07-2017 10:50 AM)AlexFekken Wrote: there are some obvious ways to cut down the number of required calculations quite a bit, as compared to a naive brute force attack. E.g. you could calculate the number of different values of n^3 mod 1000 (and then mod 10^6, then mod 10^9) that only contain the required digits. I would expect that that could narrow down the search quite a bit... [ Edit: I mistakenly thought that both the number N and the cube N^3 had to be pan-prime-digital. In reality only N^3 must be. The description below reflects my misunderstanding. The basic approach can still be applied to the problem though.] That's the approach I took last night with a C++ program and BigInt library. Multiplying two numbers with N least significant digits will result in the N least significant digits in the product, regardless of what the more significant digits are. So if you start with the pan-prime-digits and cube them. You find that for any number N ending in 2, N^3 will end in 8, so it can't be a pan-prime-digital cube. Thus any pan-prime-digit cube must end in 3, 5, or 7. Next you prepend 2, 3, 5, and 7 to these suffixes and test them. Here you find that any pan-prime-digit cube must end in 25, 33, 25, 37, 53, 55, 75 or 77. The program repeats the process until there are no more suffixes. I hoped that the number would eventually shrink. Boy was I wrong. My program ran all night. When I stopped it, it was checking 10 million+ 35-digit suffixes and hadn't found a solution yet. I was running it on a slowish computer at work. I'll try running it on my laptop which has more horsepower. Joe can you confirm that the answer you found is more than 35 digits? |
08-07-2017, 07:57 PM
Free42 (what else?) is fast enough. Well, still a couple of hours.
1 405 349 897 ^3 = 2 775 577 757 352 755 375 573 357 273 Cheers, Werner |
08-08-2017, 12:01 AM
(This post was last modified: 08-08-2017 01:12 AM by David Hayden.)
(08-07-2017 07:57 PM)Werner Wrote: 1 405 349 897 ^3 = 2 775 577 757 352 755 375 573 357 273I don't think this counts. The input number must be pan-digital also. This one contains 0, 1, 4, 8, and 9, and it lacks 2. [Edit: I see that I'm wrong. The input number does NOT need to be pan-prime-digital. Back to the drawing board!] |
08-08-2017, 12:53 AM
Rereading the first message and the base number doesn't have to be pan-digital -- the example of the square is such.
Pauli |
08-08-2017, 06:38 AM
RE: Fun with Numbers: The Pan-Prime-Digit Cube Hypothesis | |||
08-08-2017, 01:50 PM
(08-08-2017 06:38 AM)Werner Wrote:(08-07-2017 07:09 PM)David Hayden Wrote: Thus any pan-prime-digit cube must end in 3, 5, or 7.Or 8. This is what I noticed, too. So I wrote a program for the Prime using lists of usable endings , ran out of memory after the last 6 digits were checked. Now I try to find an improvement. Arno |
