Stats Inference Row Delete
06-17-2017, 10:45 PM
I have a problem with row delete in the
Inference/Goodness of Fit/Probability <Num View, ObsList/ProbList>
Pressing <Del> key brings up a menu --
1 Row 2 Column 3 All
Doesn't seem to work on the physical Prime, if I want to delete a row in the middle or bottom of the screen (rows 3 and higher), but works for the first two, uppermost rows. Strange. The editor in other stats apps might be experience the same problem, but I didn't check those.
2 Column and 3 All work fine.
06-17-2017, 11:24 PM
RE: Stats Inference Row Delete
Thanks. I'll put it on the list.
There is some custom code needed in "non-standard" numerical editors and perhaps something was missed there.
TW
06-17-2017, 11:42 PM
Thanks - -
and while we're at it, on my wish list would be a normality test, like Kolmogorov-Smirnov, or something similar. I believe there is an older thread about that on this forum, and Xcas has a KS test already. So why not make it available to the Prime as well?
One can always dream . . .
