Integer Division
03-05-2014, 09:29 PM
Integer Division
Is there an operator for integer division? (I know about IP(value), but was looking for something like '\').
Thanks,
-Dale-
03-05-2014, 10:39 PM (This post was last modified: 03-05-2014 10:39 PM by Mark Hardman.)
RE: Integer Division
(03-05-2014 09:29 PM)DrD Wrote:  Is there an operator for integer division? (I know about IP(value), but was looking for something like '\').
You have the Integer Quotient CAS command "iquo()".
In algebraic mode: iquo(122,3) returns 40.
In RPN mode: 122 Enter, 3 Enter iquo(2) returns 40.
Mark Hardman
Ceci n'est pas une signature.
03-05-2014, 10:40 PM
Thanks,
-Dale-
Are you looking for iquo(a,b) or if you want the remainder as well iquorem(a,b) in the CAS?
Cheers, Terje
03-06-2014, 10:31 AM
I was hoping to find a SINGLE character that would implement integer division. I was working with a compound expression requiring multiple integer divides, and that expression gets very l-o-o-o-n-g, with the varieties of ixxx(blah,blah) discovered so far.
Some languages use the backslash character, providing a very short solution to integer division.
Example: 5\2=2, integer version.
5/2=2.5 exact version.
(I did try to DEFINE the backslash character for this use, but \ is an invalid name input.)
-Dale-
03-06-2014, 11:44 AM
(03-06-2014 10:31 AM)DrD Wrote:  I was hoping to find a SINGLE character that would implement integer division.
I miss the "\" operator for integer division too. I'm used to it from UBASIC, which also uses "@" for mod (integer remainder).
There is no single-character integer division operator in PPL. iquo(a,b) is your shortest option, unless you make a user-defined function with an even shorter name. UDF's cannot be infix operators, however, so you're stuck with prefix notation.
<0|ΙΈ|0>
-Joe-
