User Manual Example Not Working (?)
02-27-2014, 03:05 PM (This post was last modified: 02-27-2014 03:06 PM by NMihiylov.)
Has anyone tried the example given within Chapter 7 for the Advanced Graphing App?
I am referencing example 3.) mod x = 3 each time I try to enter the calculation I receive a syntax error.
I am not that familiar with this equation - so I contacted HP support, they advised to try to run it on the emulator - I did with the same result, make sure that i have the latest firmware update...I do, then they suggested a reset. Before I reset I thought that I would check here to see if anyone else experienced the same result.
Again, it is in Chapter 7, page 125 and it is example #3
Any feedback would greatly be appreciated.
Thank you,
Nick
02-27-2014, 03:41 PM
RE: User Manual Example Not Working (?)
y mod x = 3
The y got deleted somewhere along the line. I think it was fixed in the last batch of changes made on the manual, but I'm not 100% sure on that. I will check to find out.
TW
02-27-2014, 07:30 PM (This post was last modified: 02-27-2014 07:31 PM by NMihiylov.)
Thank You Tim,
I knew the equation was missing something, but it wasn't sure what it was missing. I modified the equation in the Advanced Graphing app and was able to to recreate the graph as depicted on page 126.
Thank you for you advice.
Best Regards,
Nick
