Expanding the color TI-84+ calculator into a full computer
01-23-2017, 11:06 PM (This post was last modified: 02-25-2017 06:12 AM by Joseph_21sv.)
Inspired by the MEGA65 open computer and the color TI-84+ calculators, I had this idea for the minimum requirements for an ultimate Z80 computer:
CPU: simulates performing at least one "real" operation on an 18.32MHz Z80 (does not strictly imply using an eZ80, but the eZ80's specifications allow the most room for optimization)
Video: VGA 1024x576x16bpp (102.4 MHz dot clock), 16-bit master palette, variable chroma sampling rate, vertical/horizontal/ diagonal smooth hardware scrolling, hardware parallax scrolling, hardware split-screen scrolling, 64 sprites on screen (8 per scanline), 8x8/8x16/16x16 hardware sprite size (up to 32x32 by integer zooming), 8x8 tilemap playfield with hardware tile flipping
Audio: 1xAY-3-8910 compatible, stereo
DMA controller
512KiB base RAM (does not strictly imply using an eZ80, but the eZ80's 24-bit address mode will dispense with the need for external memory management)
Semi-compiling structured "floating"-point BASIC interpreter in ROM (not necessary for this to be in any part object-oriented, but it would be interesting)
USB (and Micro USB) I/O
10/100 Mbit Ethernet
01-27-2017, 02:14 PM
RE: Expanding the color TI-84+ calculator into a full computer
That would be cool to see.
01-30-2017, 02:50 PM
(01-27-2017 02:14 PM)Eddie W. Shore Wrote:  That would be cool to see.
Exactly what about this is it that you think would make it cool to see?
01-31-2017, 11:19 PM
It's Arm rather than Z80, but I'd say just get yourself one of these:
https://getchip.com/pages/pocketchip
02-01-2017, 04:55 AM (This post was last modified: 02-02-2017 02:00 PM by Joseph_21sv.)
(01-31-2017 11:19 PM)Dave Britten Wrote:  It's Arm rather than Z80, but I'd say just get yourself one of these:
It's also limited to composite video only unadapted and has a chiclet keyboard. That is to say, it misses two things I do like about MEGA65 (i. e. VGA video and a keyboard of full-sized keys) even in spite of viewing their grand design strategy as "hot fluidware" (the team implements particularly the CPU of the computer in field-programmable logic).
02-01-2017, 01:52 PM
(02-01-2017 04:55 AM)Joseph_21sv Wrote:  It's also limited to composite video only unadapted and has a chiclet keyboard. That is to say, it misses two things I do like about MEGA65 (i. e. VGA video and a keyboard of full-sized keys) even in spite of viewing their grand design strategy as "hot fluidware" (the team implements particularlay the CPU of the computer in field-programmable logic).
I agree that the mechanical key feel of the TI is better than the PocketCHIP, but I can type much faster on my PocketCHIP thanks to the familiar layout. The full-size USB port and bluetooth radio expand your keyboard options substantially, which is nice.
02-02-2017, 02:34 PM (This post was last modified: 02-03-2017 04:40 AM by Joseph_21sv.)
My concept of this "TI-87" is that, like many old 8 and 16 bit computers, it will come with the CPU, A/V control, RAM and ROM all packaged within the keyboard or the monitor. Forgive me if this was wrong, but I assumed name-dropping MEGA 65 first was going to be good enough to imply that the design would include a keyboard of full-sized keys.
