FW10637 SORT command bug ?
10-15-2016, 05:23 PM
[Image: show.php?id=107646]
SORT({-4,0.5,0.6,0.7,0,0,0.1})
Any idea ?
10-15-2016, 05:52 PM (This post was last modified: 10-15-2016 05:58 PM by JMB.)
RE: FW10637 SORT command bug ?
In CAS mode the answer is correct
10-15-2016, 06:40 PM
Even better:
SORT({0, 0.1}) produces {0.1, 0}
and
SORT({0,5,0.1}) gives {0.1,0,5}).
10-16-2016, 05:05 PM (This post was last modified: 10-16-2016 05:06 PM by simone_71.)
Also this one is not so bad!!!
10-16-2016, 06:31 PM
Any idea ?
FW 9069 on the iOS app and 8151 on the Andriod app gives correct results:
{-4, 0, 0, 0.1, 0.5, 0.6, 0.7}
What an embarrassing regression. Did someone miss a test case? ;-)
Ceci n'est pas une signature.
04-03-2017, 10:41 PM
Another (possible) SORT bug:
The following code works on the emulator (version 11226) but on the hardware Prime (version 10637) it returns "Error: Bad argument type":
LOCAL a,b
a:=RANDINT(1000,-99,99);
b:=SORT(a);
However, a:=SORT(RANDINT(1000,-99,99); does work on the hardware Prime.
04-04-2017, 04:18 AM (This post was last modified: 04-04-2017 04:18 AM by Spybot.)
In my case running FW 11226, both CAS & Home environments return the correct answer.
Spybot.
04-04-2017, 05:35 AM
Works here for me too...
Cyrille
04-09-2017, 12:18 PM
I see the same anomaly as reported in the original post on my physical calculator. I get the correct answer in CAS. I get the correct answer in both Home and CAS with the latest iOS version.
