(42S) GCF
07-10-2016, 04:41 AM (This post was last modified: 06-15-2017 01:48 PM by Gene.)
(42S) GCF
Prompted by Eddie W Shore's
http://www.hpmuseum.org/forum/thread-6528.html
here's my short GCD programme.
The prog takes X & Y values from stack & returns GCD , or GCF if you wish, to stack level X.
0.    { 16-Byte Prgm }
1.    LBL “GCF”
2.    LBL 00
3.    MOD
4.    LASTX
5.    X<>Y
6.    X≠0?
7.    GTO 00
8.    R↓
9.    ABS
10.    END
07-10-2016, 07:21 AM
RE: HP 42S: GCF
Same as mine, except I have a "+" in step 8 (since you know X contains zero).
I also add Smallest Common Multiple:
*LBL "SCM"
RCL ST Y
RCL ST Y
XEQ 00
x
RTN
Cheers, Werner
07-10-2016, 08:41 PM
RE: HP 42S: GCF
Is this ABS necessary?
Günter
07-11-2016, 04:26 AM
RE: HP 42S: GCF
Yes, ABS is needed for some negative inputs, otherwise the GCD is returned as a negative which is surely not the GREATEST common factor.
07-11-2016, 09:15 AM
RE: HP 42S: GCF
(07-10-2016 07:21 AM)Werner Wrote:  Same as mine, except I have a "+" in step 8 (since you know X contains zero).
*LBL "SCM"
RCL ST Y
RCL ST Y
XEQ 00
x
RTN
Cheers, Werner
What does XEQ 00 do?
07-11-2016, 10:01 AM
RE: HP 42S: GCF
Look at your own code ;-)
it does GCF, I keep them both in 1 program.
Werner
07-11-2016, 06:58 PM (This post was last modified: 07-11-2016 07:11 PM by Dieter.)
RE: HP 42S: GCF
(07-10-2016 04:41 AM)Gerald H Wrote:  here's my short GCD programme.
Fine – my fractions programs used virtually the same code, but with a final + instead of R↓ which works as a DROP here. ;-)
FTR, here is an alternate GCD routine with a slightly shorter and thus faster loop. It can be used if Z does not have to be preserved:
01 LBL 00
02 STO Z
03 MOD
04 X≠0?
05 GTO 00
06 +
07 END
And finally a solution that returns both LCM and GCD (in Y resp. X):
01 LBL"LCMGCD"
02 STO T
03 X<>Y
04 ST* T
05 LBL 00
06 STO Z
07 MOD
08 X≠0?
09 GTO 00
10 +
11 ST/ Y
12 END
This is HP41 code. HP42s users may imagine an additional "ST" in the stack related commands. ;-)
Dieter
07-12-2016, 04:46 AM
RE: HP 42S: GCF
01 LBL 00
02 STO Z
03 MOD
04 X≠0?
05 GTO 00
06 +
07 END
01 LBL"LCMGCD"
02 STO T
03 X<>Y
04 ST* T
05 LBL 00
06 STO Z
07 MOD
08 X≠0?
09 GTO 00
10 +
11 ST/ Y
12 END
Dieter
I tried the first programme but for various inputs it returned 1.
07-12-2016, 04:59 AM
RE: HP 42S: GCF
Sorry, my error, I entered STO "Z" for STO ST Z.
Now functions correctly.
