missing "WHEN" "IFTE"and "()?" ITEMs
06-05-2016, 10:45 PM
(This post was last modified: 02-16-2020 10:50 PM by compsystems.)
Hello
within the program editor, why is not the WHEN, IFTE and ()? ITEM, on TMPLT/2:BRANCH menu? IFTE is not synonymous with WHEN or ()? cmds WHEN cmd Code:
prg0(true) [enter] returns 1 on old firmware. true (new firmware) ok, thanks hpprime team prg0(false) [enter] returns 0 on old firmware. false (new firmware) ok prg0(1) -> true prg0(0) -> false prg0(-1) -> true prg0(x1) -> ((x1)? true : false) // ok, If the test is symbolic, the input value in the output expression is replaced with (?) infix operator Code:
prg1(true),prg1(false),prg1(1),prg1(0),prg1(-1) [enter] returns true,false,true,false,true prg1(x1) [enter] returns ((x1)? true : false) // ok, If the test is symbolic, the input value in the output expression is replaced with IFTE cmd, the test must always return a numerical value Code:
prg2(true),prg2(false),prg2(1),prg2(0),prg2(-1) [enter] returns 1,0,1,0,1 // ok |
06-06-2016, 06:32 AM
RE: missing "WHEN" ITEM
It's probably because the WHERE symbol (|) is accessible through the "template" key (left of the xtn key) Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
06-06-2016, 06:52 AM
RE: missing "WHEN" ITEM | |||
06-06-2016, 02:19 PM
RE: missing "WHEN" "IFTE"and "()?" ITEMs
There is no doubt that the state of the Prime can be improved. In general, things like a full suite of the commands related to the sub-menus, such as the "Branch" list, are probably more of an attempt to {get} a suggestion list, than a complete listing resource. Those menus generally haven't included CAS commands, such as the when() command, but notably missing is the similar IFTE(). That is just the way it is, for now. Personally, I would rather have the developers prioritize the "add, move, change" features, and let the dictates of time/resources clear that resulting list.
It's always a good thing to report problems, and suggestions for enhancements can't hurt, but at some point, realization that this device has growing pains is going to have to include some room for user tolerance, or it will drive you nuts. Its widely known that documentation is weak. Parisse is entirely correct, sometimes, through no fault of his, the documentation is at variance, or lacking,with respect to the operation under scrutiny. I appreciate the dedication those developer folks have shown. How much longer will this product cycle endure? -Dale- |
02-16-2020, 10:52 PM
(This post was last modified: 02-16-2020 11:04 PM by compsystems.)
ifte(true,(var1:=123),(var2:=456)) [enter] returns 123 ok [up] [up] [copy] [enter] ok
ifte(false,(var1:=123),(var2:=456)) [enter] returns 456 (false)? (123=>var3): (456=>var4) [enter] returns 456 ok, but [up] [up] [copy] [enter] error, Cause of the problem: parentheses are suppressed on the args (false)? 123=>var3: 456=>var4 https://tiplanet.org/forum/portal.php |
