RECT(#FF000000h) [8151] ≠ [10077]
04-25-2016, 04:10 AM
The definition of transparency has been reversed, this is a new syntax change ?.
I wonder if it will return to the previous syntax, since I have programs that use transparencies and let me know if you need to make changes to the following versions of the firmware.
Viga C | TD | FB
04-25-2016, 02:49 PM (This post was last modified: 04-25-2016 02:50 PM by Tim Wessman.)
RE: RECT(#FF000000h) [8151] ≠ [10077]
It actually looks like this might be specific to the hardware alone. The emulators seem to match 8151 - at least in my test I just ran.
On the list. (also, same issue as reported in this thread - http://www.hpmuseum.org/forum/thread-6128.html)
TW
