AstroLab 4 and new FW
04-22-2016, 12:11 PM
For those who use AstroLab 4, a new corrected version will be post tomorrow (saturday).
This version will work with the new FW (10077) and the past one also.
I think the function name can not exceed 30 char long in the new FW (10077).
I have change this and AstroLab 4 work well now for me with FW (10077).
Marcel
04-22-2016, 01:45 PM
RE: AstroLab 4 and new FW
(04-22-2016 12:11 PM)Marcel Wrote:  For those who use AstroLab 4, a new corrected version will be post tomorrow (saturday).
Marcel
hi Marcel,
I use it (with my Effemeridi program, that I'll check soon for compatibility).
I din't know about the "30 char" limit... Is it sure?
Salvo
04-22-2016, 02:03 PM (This post was last modified: 04-22-2016 02:23 PM by Marcel.)
Hi Salvo!
I am not sure but after the installation of the new FW, some functions of AstroLab declare error at line where I see the function "HeliocentricEclipticalCoordinates".
I decide to change it to "HeliocentricEclipticalCoor" and after that AstroLab work fine... I check and reduce all the functions names to a lenght<30 and now everything is OK.
Pleasure to write to you again!
Marcel
04-22-2016, 02:29 PM
I think it is 31.
Basically, we started enforcing a bit more checking on things to ensure avoidance of problems. Things will error now if the conflict with built in variables, exceed lengths, etc.
TW
04-22-2016, 02:36 PM
(04-22-2016 02:03 PM)Marcel Wrote:  ...
Marcel
(04-22-2016 02:29 PM)Tim Wessman Wrote:  I think it is 31.
Basically, we started enforcing a bit more checking on things to ensure avoidance of problems...
thank you both.
I'll review soon Effemeridi (I think this one is the only or one of a few set of programs of mine with "long" names...
Salvo
04-22-2016, 02:58 PM
Hi Tim and Salvo!
Thank you Tim for your help!
Nice work...
I also find that if I format a word in the Note app of AstroLab on the real calculator, the virtual calculator crash when I start the program containing this note after the transfert..
I will continue to experiment this thing...
Marcel
