HEPAX_4H: a New Library#4-aware version available
02-19-2016, 12:36 PM
(This post was last modified: 02-19-2016 12:37 PM by Ángel Martin.)
How to improve a masterpiece? Some would say it can't be done, but if you're already using some Library#4-aware modules then this new version HEPAX_4H is a clear enhancement of the original.
The basic module is unchanged, but the sub-functions management is overhauled as follows: 1.- added XFCAT and HPCAT to enumerate the sub-functions within the XF and HEPAX groups. Direct execution within the catalog is possible. 2.- added direct ALPHA entry support for the HEPAXA and XFA functions 3.- added sub-function name preview when entered as index or during SST execution 4.- added LASTF support for the last-executed sub-function. Plus the same enhancements from the previous "1G" revision are here too, as follows: - Six new functions in the MAIN FAT: HFLADR. HFLTYP, HGETP. HWRKFL, RLSRAM, and LASTF - three new sub-functions in the HEPAX group: PGROOM, PGSUM, HPCAT - five new sub-functions in the XF group: RTN?, XQ>GO, XQXM, CLEM, and XFCAT The Library#4 needed some adjustments to make this changes compatible with some code shared by the PowerCL_Extreme - which has also been modified accordingly. Therefore the three modules impacted by this action are the Library#4, the HEPAX_1H, and the PowerCL_Extreme. Soon at a TOS near you... or sneak preview for beta testers, any volunteers? ÁM |
02-19-2016, 04:34 PM
RE: HEPAX_4H: a New Library#4-aware version available | |||
02-19-2016, 04:47 PM
Excellent
02-20-2016, 08:37 AM
