RPN-1250
09-27-2015, 06:17 PM
RPN-1250
Following the repurposing of the TI-1200 into the RPN-1200 RPN scientific calculator, I wanted to take the challenge of making a programmable version by repurposing the TI-1250, which is has the same enclosure and basic design as the TI-1200 but has an extra row of keys (6 rows instead of 5 for the TI-1200). The result is the RPN-1250 (see pictures)
The design is based on a 64kbyte flash Microchip PIC 18F2680 driving a MAX 7219 8-digit 7-segment LED driver. The software is programmed in C with the Microchip IDE MPLAB X. Functionalities as below: - 4-level stack RPN scientific with conversions - 20 memories (0 to 9 and .0 to .9) with store and recall arithmetic - All memories and stack can be saved to and recalled from the 'constant' flash memory of the PIC - programmable 98 steps (like the HP-29C) with alphanumerical display of the program - 3 programs can be saved to and recalled from the 'constant' flash memory of the PIC - 20 labels (0 to 9 and .0 to .9), subroutines, all 12 tests, PAUSE and VIEW functions, SST execution - Speed roughly 8X the HP-41C What it does not have (vs HP-29C) is: - ISZ/DSZ - indirect addressing - ABS function but this can be easily programmed as x<0? CHS - Polar/Rectangular conversions (sorry Den) There can easily be implemented but there are not any keys left to include them without complicating the UI - any suggestions? Hope I will have a chance to show it to HHC 2016 ! Benoit |
09-27-2015, 08:40 PM
RE: RPN-1250
Very nice! Is the software open source?
Might be tempted to make an RPN-1250 myself then ![]() |
09-27-2015, 09:42 PM
RE: RPN-1250
(09-27-2015 06:17 PM)Benoit Maag Wrote: Following the repurposing of the TI-1200 into the RPN-1200 RPN scientific calculator, I wanted to take the challenge of making a programmable version by repurposing the TI-1250, which is has the same enclosure and basic design as the TI-1200 but has an extra row of keys (6 rows instead of 5 for the TI-1200). The result is the RPN-1250 (see pictures) Nice going Benoit! I look forward to seeing it! -Jonathan |
09-28-2015, 02:01 AM
(This post was last modified: 09-28-2015 02:11 AM by matthiaspaul.)
RE: RPN-1250
(09-27-2015 06:17 PM)Benoit Maag Wrote: What it does not have (vs HP-29C) is:The original layout (as far as I could decipher it on the photo): Code:
- Combined CLR and ALL. First F+CLR will invoke "Clear", either F+CLR+< (or F+CLR immediately followed by F+CLR again) will invoke "Clear All". - Added P>R and R>P functions - Added |x| function - Rearranged some assignments for an IMHO more logical, easier to memorize layout and more convenient usage (although various compromises had to be made given the very limited number of keys): - EEX directly invocable and part of the numpad - pi is often on the same key as EEX - IP/FP are semantically related to decimal points - PSE is often on same key as 0 - RCL is used more often than STO - Operations 1/x and +/- are frequently needed and typically located close to Enter - Rv and x<>y are frequently needed stack manipulations and should be easily accessible - LOG and 10^x in same column as 1 for mnemotical reasons - LN and e^x in same colum as 2 for mnemotical reasons (e=2...) (Another possible order instead of LOG/LN/SQRT could be SQRT/LN/LOG, but it would not group SQRT near y^x.) - Enter key above op keys, not below them. This makes the four op keys line up nicely with the numpad - Delete (<) in upper right corner Greetings, Matthias -- "Programs are poems for computers." |
09-28-2015, 02:36 AM
RE: RPN-1250
(09-28-2015 02:01 AM)matthiaspaul Wrote:(09-27-2015 06:17 PM)Benoit Maag Wrote: What it does not have (vs HP-29C) is:The original layout (as far as I could decipher it on the photo): Matthias, Thank you for the suggestions ! I will look into that. BTW, there were a few things tha are not visible on the keyboard: - pressing F/G 3 times currently loops back to no prefix (CLEAR-PREFIX) - maybe I can use NOP as the CLEAR-PREFIX option, or as R/S. - G-ENTER actually calls an Escape Mode where the display brightness can be adjusted, the version of the software can be displayed and so on. So I would need a way to get there. Benoit |
