(49G) Arabic to Pseudo-Roman Representation (OEIS A093788)
09-03-2015, 03:46 PM (This post was last modified: 06-15-2017 01:46 PM by Gene.)
The programme takes an integer as input & returns the Roman representation in Arabic numerals.
eg For input
1953
otherwise known as
MCMLIII
the programme returns
1000100100050111
which is the letter by letter, left to right, value of the Roman letters.
For further info see
http://oeis.org/A093788
  CK1&Dispatch
  # FF
    FPTR2 ^DupQIsZero?
    caseSIZEERR
    FPTR2 ^Z>S
    TOTEMPOB
    CODE 00048 8FB97601438F15811137135CD472819F1CCC4C213414F14A14C149171181CD5BE8F34150
    NULL$SWAP
    DUPLEN$
    #1+_ONE_DO
    DUPINDEX@
    SUB$1#
    BINT48
      DUP#0=
      ?SEMI
      BINT1
      #=casedrop
        Z1_
      BINT2
      #=casedrop
        Z1_
        Z1_
      BINT3
      #=casedrop
        Z1_
        Z1_
        Z1_
      BINT4
      #=casedrop
        Z5_
        Z1_
      BINT5
      #=casedrop
        Z5_
      BINT6
      #=casedrop
        Z1_
        Z5_
      BINT7
      #=casedrop
        Z1_
        Z1_
        Z5_
      BINT8
      #=case
        Z1_
        Z1_
        Z1_
        Z5_
        Z10_
        Z1_
    DUP#0=ITE
    DROPNULL$
      INNERCOMP
      NULL$SWAP
      ZERO_DO
      SWAP
      Z10_
      JINDEX@
      #1-
      FPTR2 ^RP#
      FPTR2 ^RMULText
      FPTR2 ^Z>S
      LOOP
    ROT
    &$SWAP
    LOOP
    DROP
    FPTR2 ^S>Z
09-04-2015, 08:10 AM
RE: HP 49G: Arabic to Pseudo-Roman Representation (OEIS A093788)
Here a slightly improved version of the programme:
  CK1&Dispatch
  # FF
    FPTR2 ^DupQIsZero?
    caseSIZEERR
    FPTR2 ^Z>S
    NULL$SWAP
    DUPLEN$
    ZERO_DO
    DUP
    ISTOP-INDEX
    SUB$1#
    BINT48
      DUP#0=csDROP
        BINT1
        #=casedrop
          Z1_
        BINT2
        #=casedrop
          Z1_
          Z1_
        BINT3
        #=casedrop
          Z1_
          Z1_
          Z1_
        BINT4
        #=casedrop
          Z5_
          Z1_
        BINT5
        #=casedrop
          Z5_
        BINT6
        #=casedrop
          Z1_
          Z5_
        BINT7
        #=casedrop
          Z1_
          Z1_
          Z5_
        BINT8
        #=case
          Z1_
          Z1_
          Z1_
          Z5_
          Z10_
          Z1_
      INNERCOMP
      NULL$SWAP
      ZERO_DO
      SWAP
      Z10_
      JINDEX@
      FPTR2 ^RP#
      FPTR2 ^RMULText
      FPTR2 ^Z>S
      LOOP
      ROT
      &$SWAP
    LOOP
    DROP
    FPTR2 ^S>Z
02-21-2017, 11:51 AM
Another improved(?) version:
  CK1&Dispatch
  # FF
    FPTR2 ^DupQIsZero?
    caseSIZEERR
        Z1_
        Z1_
        Z1_
        Z1_
        Z1_
        Z1_
        Z1_
        Z5_
        Z5_
        Z5_
        Z1_
        Z5_
        Z1_
        Z1_
        Z5_
        Z1_
        Z1_
        Z1_
        Z1_
        Z10_
    NULL$
    ROT
    FPTR2 ^Z>S
    DUPLEN$
    ZERO_DO
    DUP
    ISTOP-INDEX
    SUB$1#
    BINT48
      DUP#0=csedrp
      NULL$
      4PICKSWAP
      NTHCOMPDROP
      INNERCOMP
      NULL$SWAP
      ZERO_DO
      SWAP
      Z10_
      JINDEX@
      FPTR2 ^RP#
      FPTR2 ^RMULText
      FPTR2 ^Z>S
      SWAP&$
      LOOP
    ROT
    &$SWAP
    LOOP
    DROPSWAPDROP
    FPTR2 ^S>Z
