Taylor Expansion not working
08-14-2015, 05:38 PM
I have been a long time user of the 48SX and GX and just got a 50g to replace the SX.
So....and now I want to do a taylor expansion of sqrt(0.2*x+1)
So...first when i assemble the root is asks me to turn on approx mode - OK
I put on the stack
> sqrt(etc)
>'X'
>5
and i get the message: "Approx mode off"
...OK...
Next it s pop-up: "TAYLR error: Mode switch not allowed here "
hmmmmm.....works on the SX. Can someone give me a hint how to do that?
Wolfram
08-14-2015, 06:54 PM (This post was last modified: 08-14-2015 06:56 PM by Gerson W. Barbosa.)
RE: Taylor Expansion not working
Try replacing 0.2*X with X/5
08-14-2015, 07:25 PM
(08-14-2015 06:54 PM)Gerson W. Barbosa Wrote:  Try replacing 0.2*X with X/5
Ok, this equation was just an example ..i actually need (0.000231*x+0.1296480889)^0.5
08-14-2015, 08:33 PM
In exact mode,
'√(231/1000000*X+1296480889/10000000000)'
'X'
3
TAYLR
'5788125000*√1296480889/1637269993841868597755699*X^3-55125*√1296480889/13891427235886201*X^2+21*√1296480889/2357237980*X+√1296480889/100000'
You might need to set flag -79 (Textbook off).
HTH,
Gerson.
08-14-2015, 09:37 PM
(08-14-2015 08:33 PM)Gerson W. Barbosa Wrote:
(08-14-2015 07:25 PM)wneff Wrote:  Ok, this equation was just an example ..i actually need (0.000231*x+0.1296480889)^0.5
In exact mode,
'X'
3
TAYLR
HTH,
Gerson.
Super that worked! Thanks a lot. Now - this seems weird to me that it can't just give me the polynomila numbers as decimals - is there a way to chenage settings to get that done?
08-17-2015, 05:16 PM
I believe you can use the ->Q command under the Convert>Rewrite menu to do the conversion from decimal to fractional automatically, at least it seems to be working on your example, giving
sqrt(1/4329*X+129/995)
After that you could perform the Taylor expansion.
Hope this help.
