(42S) Iterative refinement
07-23-2015, 08:11 AM
(This post was last modified: 06-15-2017 01:28 PM by Gene.)
See the article with the same subject. I never know where to post these, so I put them in both :-). And comments are disabled for articles, for some reason.
Quick usage instructions: Put A and b on the stack, just as you would for a normal solve, so b ENTER A Then XEQ "/IR" will solve the system and perform a corrective refinement step, leaving the result in X. If you are careful to leave the stack undisturbed (as browsing the result with EDIT, arrows, EXITALL will do), you may execute further refinement steps with R/S. Code: L X Y Z T Werner |
07-23-2015, 09:32 AM
RE: [42S] Iterative refinement
Nicely done. Bravo!
07-23-2015, 01:14 PM
(This post was last modified: 07-23-2015 01:20 PM by Gerald H.)
I have to contradict you - the programme will NOT run the example you give on FREE42.
Line 26 produces a "Dimension Error". |
07-23-2015, 01:39 PM
Yes, a bug in Free42!! I never thought I'd see the day - I never did try it out on Free42 as it is useless anyway, and (for another program under development) I tried and used so many matrix-specific things that all worked perfectly, that I trusted Free42 unconditionally.
But INSR does not disable stack lift as it does on a 42S, hence the error (caused by the -1 not overwriting the 0 put there by INSR, but pushing it on the stack) I'll post it in the Free42 google group. Thanks, Werner |
07-25-2015, 05:21 AM
Happily the programme works on the go42S emulator for android.
07-25-2015, 07:18 AM
Just adding a CLX in front of -1 will make it run on Free42 as well, but it's useless. Free42 does not use more digits when evaluating dot products, (it already uses the maximum available in the Intel Decimal floating-point library), and so we can't improve on the results of the first solve operation.
Werner |
07-25-2015, 08:30 AM
I dislike the epithet "useless".
Your programme is an economic implementation of the algorithm. Didactically excellent. That it doesn't improve the result on free42 shows that free42 is not truly an emulator but rather a fine calculator very closely modelled on the 42s. The programme found a bug in free42 - surely a useful accomplishment? Hope the bug will shortly be eradicated in a new free42 version. As a real emulator I recommend go42S. |
02-29-2016, 08:55 AM
The INSR bug has been fixed on free42 1.5.7 - Bravo!
What do you think of the new action bar? |
