(48G) 48G, 49G & 50G: Explicit Inverse Congruential Random Number Generator
07-23-2015, 07:21 AM (This post was last modified: 06-15-2017 01:51 PM by Gene.)
An Explicit Inverse Coungruential Random Number Generator to base 2 ^WORDSIZE.
SDR seeds constants a & b with suitable values to ensure maximum period & the counter j with a random value.
NEXTX produces the next hexadecimal string in the sequence using the formula
next := j * ( j * a + b ) ^ -1 MODULO 2 ^ WORDSIZE
where j increases by 1 at each iteration.
NEXTR returns the next real in the sequence, next divided by the modulus.
TO USE:
Set wordsize as required, actuate SDR - NEXTX or NEXTR will then return the sequence you require.
I would be grateful for reports of (in-)adequacy of the randomness of sequences produced.
SDR
  CK0
  BINT3
  ZERO_DO
  BINT2
  ZERO_DO
  %RAN
  % 1.E12
  LOOP
  bit*
  LOOP
  ID j
  STO
  HXS 00001 4
  DUPUNROT
  bit/
  bit*
  HXS 00001 2
  bit+
  ID a
  STO
  HXS 00001 2
  DUPUNROT
  bit/
  bit*
  HXS 00001 1
  bit+
  ID b
  STO
NEXTX
  CK0
  ID j
  DUPDUP
  HXS 00001 1
  bit+
  ID j
  STO
  ID a
  bit*
  ID b
  bit+
  HXS 00001 1
  SWAP
  WORDSIZE
  #1-
  ONE_DO
  DUPUNROT
  bit*
  SWAPDUP
  bit*
  LOOP
  DROP
  bit*
NEXTR
  CK0
  ID NEXTX
  HXS>%
  %2
  WORDSIZE
  FPTR2 ^RP#
