(49G) A Fibonacci-like Sequence with Only Composite Members
07-09-2015, 05:10 PM
(This post was last modified: 06-15-2017 01:47 PM by Gene.)
A programme to produce a Fibonacci-like sequence but starting with zeroth element
106276436867 & first element 35256392432 the following numbers being the sum of the preceding two elements of the series. Interestingly, every element of the series is a composite number. Input an integer N to find the Nth sequence element. Code:
