HP Prime - Home view imaginary numbers error message? (resolved)
05-05-2015, 12:15 PM (This post was last modified: 05-05-2015 01:26 PM by CR Haeger.)
It seems that entering negative numbers under a radical (i.e. sqrt(-8)) yields Error: Invalid input in the Home screen.
This does not create any errors in CAS --> sqrt(2)*2*i
Seems to happen whether in algebraic or textbook mode. Software version 2014 11 24 (6940)
Thanks
05-05-2015, 01:05 PM
RE: HP Prime - Home view imaginary numbers error message?
did you mark the option "Allow complex output from real input" at the "Home Settings"?
Greetings
Dirk.
05-05-2015, 01:15 PM (This post was last modified: 05-05-2015 01:16 PM by CR Haeger.)
RE: HP Prime - Home view imaginary numbers error message? (resolved)
Of course I didn't....
Thanks, that did the trick.
