Reset integrating a function
01-31-2015, 10:42 PM
(This post was last modified: 01-31-2015 10:55 PM by salvomic.)
hi all,
I try: g(x):=x^2 then int(g,x) - (also with the graphic tools on C key...) HP Prime reset and g variable is reset also. Is it only a problem by me or...? Any workaround? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-31-2015, 11:16 PM
RE: Reset integrating a function
Did the emulator crash?
See attachment. |
01-31-2015, 11:18 PM
(01-31-2015 10:42 PM)salvomic Wrote: int(g,x) - (also with the graphic tools on C key...) Try int(g(x),x) TW Although I work for HP, the views and opinions I post here are my own. |
01-31-2015, 11:49 PM
Hello Salvo,
I could reproduce the crash for g(x):=x² and int(g,x). This also happens for int(g) or f(t):=t² and int(f,t), whereas int('sin') or int(f) or h(x):=c and int(h) are mostly fine (somewhat strange results nevertheless). Since I don't know if a functional form of "int" makes sense anyway (how should it behave for functions with two or more parameters?) -- as opposed to "diff" --, you should use only expressions as arguments (see on-calc help) as Tim suggested. |
02-01-2015, 09:05 AM
hi all,
here emulator crashes also, but without warning, only message for crash... int(g(x),x) seems to be ok, as it must be. Yeah Tim, it's correct, I know, but if there is a way to avoid reset it's better: the calculator should only give an error not reset, also if the reset it's not deadly cheers ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
02-01-2015, 09:27 AM
Just checked on emulator, I can not reproduce a crash.
And yes, it would probably be meaningfull to make int(g) work like g'. |
02-01-2015, 01:06 PM
(This post was last modified: 02-01-2015 01:37 PM by Snorre.)
(02-01-2015 09:27 AM)parisse Wrote: Just checked on emulator, I can not reproduce a crash.Did you name the parameter "x"? Just asking because it matters: g(x):=x and int(g) crashes my device quite reliable. f(t):=t and int(f) doesn't crash it, but returns (t)->(t*x). So, "int" does not care about the actual parameter as "diff" would do, but always assumes "x" to be the integration variable. h(x):=c and int(h) doesn't crash, but returns _x->(c*x(_x)) if CAS setting "Exact" is checked, or "Error: Bad Argument Value" if unchecked. BTW: if CAS setting "Exact" is unchecked I cannot do a simple "restart", so have to either re-check it or do "restart(NULL)". P.S. Maybe helpful to see what's going on: int(h) says "Warning, evaluating (integrate((x)->c,x))(_x) as a function not as a product". |
02-01-2015, 03:05 PM
Yes, tried with x as variable. But revisions may differ.
02-01-2015, 03:11 PM
(02-01-2015 03:05 PM)parisse Wrote: Yes, tried with x as variable. But revisions may differ. I've firmware 6975, hardware A... ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
02-02-2015, 08:51 AM
It probably means that the crash has been fixed since then.
02-02-2015, 08:54 AM
(02-02-2015 08:51 AM)parisse Wrote: It probably means that the crash has been fixed since then. well, 6975 isn't the last public released firmware upgrade? Is it info about the next release? Merci! ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
02-02-2015, 01:57 PM
All I can say is that it's fixed in Giac/Xcas sourcecode base.
02-02-2015, 02:12 PM
(02-02-2015 01:57 PM)parisse Wrote: All I can say is that it's fixed in Giac/Xcas sourcecode base. ok! ;-) ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
User(s) browsing this thread:
