Opening more than 1 instance of the virtual calculator
01-24-2015, 02:45 AM
I discovered that more than 1 instance of the virtual calculator can be opened on the PC, and they show up in the CK. Is this by design? I did not pursue this any further, because I didn't want to mess up what I had in the virtual calculator I opened first. Thanks
rcf
01-24-2015, 11:11 AM (This post was last modified: 01-24-2015 11:13 AM by Hlib.)
RE: Opening more than 1 instance of the virtual calculator
(01-24-2015 02:45 AM)Bob Frazee Wrote:  I discovered that more than 1 instance of the virtual calculator can be opened on the PC, and they show up in the CK. Is this by design? I did not pursue this any further, because I didn't want to mess up what I had in the virtual calculator I opened first. Thanks
rcf
[Image: f9d3a6efef73t.jpg]
You meant it? Sometimes it is comfortably to have several independent apps. near at hand.
01-24-2015, 12:56 PM
You can give a name to each calculator.
I use this feature 'several primes' e.g. testing several firmwares.
Attached File(s)
.pdf  Primes.pdf (Size: 1.51 MB / Downloads: 18)
HP 33C 34C 11C 41CX 32S 28C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more
01-27-2015, 09:29 AM
yes, it's by design.
Each prime will also create a separate directory in your %APPDATA% folder.
Now, if you want to re-access the 3rd directory, you need to open 2 primes, and the 3rd one will open the 3rd directory... Not the best UI, but it will work.
cyrille
