Sub-menu for Drawmenu?
01-17-2015, 05:32 PM
Is there a function to implement sub-menu's? Once DRAWMENU() has created menu buttons, I would like to pop up a sub-menu, triggered from a menu button. How are sub-menu's accomplished?
01-21-2015, 01:41 PM
RE: Sub-menu for Drawmenu?
Referring to the program's catalog soft button 'More' i would like to know this, too.
Using command 'Choose'? How to get the position of the choose box?
Thank you.
HP 33C 34C 11C 41CX 12C 15C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more
01-21-2015, 03:29 PM
I tried drawing my own sub-menu's, but it was not worth the overhead. I then tried using choose boxes, triggered from the main menu, to supplement additional options. For my specific needs, there were only two additional choices needed in the sub's, so this idea worked well.
Sub-menus are going to be tricky, I'm afraid.
01-21-2015, 04:16 PM
DRAWMENU() does only that -- draws a menu. You have to create your own keyboard/touchscreen handler to handle all user input.
It's quite limited compared to what you could do with the HP48, HP49 and HP50
Graph 3D | QPI | SolveSys
01-22-2015, 10:43 PM
Hello.
You can use the technique of Hp 48.50 or Ti 85.86 .
Each option DRAWMENU the first calls for a new DRAWMENU.
