Applications
01-09-2015, 05:51 PM
Applications
Is there a way to use the answer from an application in the home screen?
01-09-2015, 06:04 PM
(This post was last modified: 01-09-2015 06:08 PM by Tim Wessman.)
RE: Applications
Almost always - yes!
You can find most calculations/results in the application variables. For an example, VARS->[APP]->Stat1Var->Results->MedVal. That is the best way if you are going to use it many times or for futher calculations. Should there be a result that isn't there in the app vars, or if it will be easier, you can always copy/paste. With the result you like selected, press SHIFT-VIEW (COPY) and then paste as desired. If you can't find a result, please let me know because we tried hard to make sure everything was available outside. TW Although I work for HP, the views and opinions I post here are my own. |
User(s) browsing this thread:
